1 - 3 of 3 Posts
G
Honda Durakon Tonneau Cover System
Replacement Key Ordering Procedure
2006 Ridgeline
This bulletin describes the procedure for ordering replacement keys for the 2006 Ridgeline Bed Tonneau Cover System.
To order a replacement key, use the stamped code on the existing key (if available) or the corresponding cylinder lock.
Each key and its corresponding cylinder lock are stamped with the same three-digit code.
YOU HAVE TO GO TO YOUR DEALER IN ORDER TO DO THIS BUT I THOUGHT BY GIVING YOU THIS INFORMATION AHEAD OF TIME IT MIGHT HELP EXPEDITE THE PROCESS.
Hi Ladyridge!!! Bought a couple of spare key blanks thru the lock manufacture and had them "cut" locally...My Honda dealer couldn't find out any information about a month ago. There should be some old postings on this site about this information. ;)
G
Yes you're right. But my fear is you will have to go through Honda now to get them. Everything is worth a try.
:D
1 - 3 of 3 Posts
