Having both Metric and Imperial sockets along with the appropriate 3/8" drives makes disasembly of most mechanical products easy.
However am old school and have not encountered these Torx heads previously. Whem I purchased my new Ridgeline in the autumn of 2011 was the first time I had seen Torx used extensively!
So my question is how does one determine what Torx are required? For example the fastening fixtures in the rear bed are all Torx; in the days past one would grab a socket and see if it fit the head; not so with Torx.
My question is what Torx devices are required (size and type etc.) to work on the Ridgeline?
I should add had an excellent good shadetree mechanice (he could and did repair anything) when the amateur radio antenna rack was installed between the rear upper tie-down brackets three years ago. Sadly he is has passed and his entire workshop was sold at auction.
So now need to do some maintenance on same; and the part that stymies me are the Torx fastening devices? Suggestions anybody?
