I am ready ready to tow a four winds lite pull behind. About 4000 lbs. I have level bars but the Ridgeline manual says not to use them. Does anybody have experience with this?thanks
Is the 5000 lbs fully loaded ready to travel or the dry weight? If its the dry weight your maxed out.Bump.. I would like to know, as well. Although I have a 5,000 lbs trailer.
Very important: also have the maximum axle capacities and know how much weight can be added on top of how you'll normally load it. The bars will shift some weight from rear to front axles.They key word is "not advised". If it set up correctly its all good. Call E-Trailer and have all your info in hand on trailer tongue weight(fully loaded ready to travel), trailer weight, and tow hitch max capacity.
Your trucks trailer hitch must be weight distribution approved. There should be a sticker on the hitch that has the info. Happy trails.
They rate the Honda at 5k max towing cap. Your call.KTMRICK- The trailer is 4,290lbs + 700lbs in gear(approx). Tongue weight is 430 lbs.
