1 - 5 of 5 Posts
I was installing the brake controller in my 2022 yesterday and noticed this module tucked up behind the steering shaft bears a Toyota label. The logo is different, so perhaps this is not the same Toyota that makes the Previa and the Mister 2.
I realize there is a finite number of suppliers of automotive hardware so this isn't a huge surprise. But interesting nonetheless.
Steve
This is a DC-DC converter (Honda also refers to it as a "voltage stabilization module") made by Toyota Industries Corporation, a subsidiary of Toyota Group - the company that owns Toyota Motor Corporation which makes Toyota automobiles.
The Ridgeline has used this DC-DC converter since the 2020 model year when it gained auto idle stop.
According to the service information, "the DC-DC converter boosts the voltage to compensate for voltage loss that occurs when restarting the engine in order to provide a stable power supply to each electrical component of the vehicle. The DC-DC converter is activated by a start signal from the PCM."
Rectangle Font Line Parallel Pattern
Rectangle Slope Font Line Parallel
“gained auto idle stop.”
Except for unwanted weight, I thought “gained” generally referred to attributes or positive references. 😊
Roger, I’m aware that you just meant “the addition…”.
Idle stop, VCM?
This is a question. Considering the starter, battery, electronic hardware, computer changes, maybe extra maintaince , how much does all this actually cost the owner? How much does it affect the EPA results? Then DI verses port injection?
For a while, the increasing sophistication seemed to be beneficial, cost-wise, such as the EFI in my 72 VW 412 wagon vs the carburetors in my ‘64 & ‘68 VW bugs and other improvements up until maybe the mid 2000’s or even early 2010’s. But now, reliability and extra costs of the “sophisticated systems “ seem to possibly be counter-productive. Appliances such as washing machines, dryers, refrigerators, freezers, dishwashers, etc are supposedly more efficient but much shorter lived - 2,3,4 times shorter lived. Are vehicles going in the same direction? Our 2006 Lexus RX400h (1st year hybrid) went 11 years and over 150K miles with NOTHING going wrong. Can I expect the same with my 2022 RTL-E?
Idle stop, VCM?
When the J35 switched from port injection to direct injection and added VCM, the Ridgeline went from:
250 > 280 HP
247 > 262 lb-ft torque
17 > 21 MPG combined fuel economy
When auto idle stop was added to the Ridgeline, the combined fuel economy didn't change, but it lost 1 MPG on the highway and gained 1 MPG in the city. The 1 MPG city gain is likely the result of auto idle stop and a taller starting gear ratio. The 1 MPG highway loss must be due to the 9-speed transmission.
There's no money in making things last as long as they used to. :)
Roger, et al,
My previous Honda before my 2017 RTL-E was a 2013 V-6 Accord. Port injected and 278 hp. We kept it between 2-3 years and sold only because we needed a larger vehicle (SUV). A very close friend bought it. Now, with 105,000miles, it still is trouble-free. Right or wrong (likely wrong) , I changed the oil every 5K miles. Still looked clean.
So, the current RL engine (DI as most know) has 280 hp while the ‘13 Accord had only 2 hp less. If the Accord engine were used in the “truck” maybe it would have been retuned for more torque/less max hp.
Still, what I saw was a 2 hp increase in the ‘17 RL (over the ‘13 Accord) with DI FIs that had to be replaced (‘17) , likelihood of carbon buildup on the back of the valves, potentially more frequent FI replacements plus FI pump operating at a much higher pressure and possible/likely? more frequent replacement. Probably, more expensive injectors and fuel pump. On the surface, this appeared to be more loss than gain.
On the surface, the 9-sp seems like it would be at least as fuel efficient as the 6-sp; but, my ‘22 gets a little less milage than my ‘17. The controllability of the 9-sp outweighs any other factors, imo. The confidence in the 9-sp greatly outweighs the 6-sp, imo.
The front end of the ‘21-‘23 looks more draggy than the ’17–‘20. The drag index just looks higher.
1 - 5 of 5 Posts
