Okay, so my truck is at the tire shop getting some new shoes when I get this call...
"TPMS valves won't tighten against the rims"
A little backstory... I had steel wheels, bent one, so I bought a set of aluminum rims from a guy locally. Had my tires mounted on there with normal valves. Everything was okay, except for the TPMS light in the dash.
I bought the TMPS rebuild kit and put my old sensors on it, now when they're trying to install it, it won't tighten up to the rim. They say it appears somebody has messed with it, but it hasn't been machined or anything like that.
My question is this - Can I use an extra rubber washer to make them tighten up or are my rims scrap if I want TPMS?
Next question - where do I unplug the TMPS so the light isn't on in the dash while I figure this out?
:act060:
I did a google search and found a similar issue on the Acura forum. There was no mention of noticing that the rim had been modified in any way, but a fellow member suggested that their local tire shop told him the same, but upon taking it to the Acura dealer, they showed him that it did in fact fit, just had to be put in there a certain way? I can't imagine that is actually the case? It's like a screw on valve stem, you put it through the valve stem hole and screw the top on until it's tight...
Anyhow, if anybody has any suggestions or have dealt with anything similar, let me know!
:act060:
