1 - 5 of 5 Posts
The TPMS light is coming on after 5 or so miles of driving. I had replaced the tires a week after I bought the truck and then drove to NC and back, near 2000 miles without a problem.If I shut the truck off the light will go off then come back on. I've checked the pressure in all the tires multiple times and at different pressures. Any thoughts?
2014 Sport
I assume you are getting the "TPMS" light rather than the low tire pressure warning light? If so, this light indicates a fault in the TPMS system rather than any issue with low tire pressure.
Are your sensors original? 8-10 year lifespan would put a 2007's sensors at the end of the run. My 06's sensors have reached the end of their life. Sometimes I get no TPMS fault light but most of the time I do. My sensors need to be replaced . . .
· Premium Member
My '06 is doing the same. I get TPMS light and sometimes it shows left rear. I checked the pressure and it's fine. I even went a pound or 2 over and it still lights up so I guess it's sensor time.
Discussion Starter · #4 ·
Right. The TPMS light. Any ideas why it would not come on as soon as the truck was started or right after? That would be a bummer f I had to replace them. I just shelled out 25 buck a wheel to have the tires mounted and balanced
2014 Sport
Its probably just the nature of the system when the batteries are starting to go. It may be possible for someone with a scanner that is capable of reading Honda specific codes to read the battery levels in your sensors. Certainly a dealer could do it but that might cost more than 4 aftermarket sensors.
1 - 5 of 5 Posts
