I am having a problem with my brake controller/wiring on my 2014 RL and was hoping someone could help steer me in the right direction...
I bought the truck in January and installed a Prodigy P2 with the plug-in wiring adapter. Installed easily and hooked right up to my trailer, no problems. I have been towing at least once per week with no problems.
Then, I took the truck in for an oil change yesterday (to the dealer) and when I hooked the trailer up today, nothing. P2 is showing "nc" error, which evidently means no connection.
Here's what I have tried:
- cleaned both sides of truck-trailer connection with contact cleaner
- tested voltage coming out of controller (tested at 12 v)
- tested continuity of controller wiring harness (also ok)
- physically inspected the wires going into 7-way plug at back
- tested continuity of wiring on trailer side (also ok)
My thinking is I need to next take apart the factory 7-way plug at the back to check for a loose connection. Any other thoughts or suggestions on what to try?
