I have a 2009 RL RT aftermarket leather. I read ROC very often... Just don't post much.
I have read everything I can find on Ridgeline towing, but still am scratching my bald head.
I pull a 2017 R Pod 180. 2600 lbs empty.. 3500 loaded to go. Ridgeline pulls nicely, no problem. But, the transmission has my attention. When at speed, 65 on interstate is my personal limit, or even at 60 on state roads, the transmission constantly shifts. But I am not sure that is exactly correct either. Here is my question....
The transmission is a 4 speed automatic, right ? After it shifts into fourth, it then shifts again which I have always considered it to be the differential locking up into an overdrive mode. That is what keeps shifting.. In and out of that "overdrive mode". Constantly. Did it for years when I was pulling my very light weight Casita travel trailer also.
So, I just made my mind up to put the cruise control on and let the computer manage the transmission. Result remains .. Constant shifting .. So what, does this really hurt anything ?
Now, have studied owners manual agail tonight..
States clearly there are 5 speeds to the transmission ... Huh? Is that extra shift after 4th a real gear? If so, can I lock it out and not use it .
Also, the owners manual states clearly to never exceed 55 mph when pulling a flat sided trailer ( camper ) ... Huh again. Is that true ? If so, I can't live with that.
I love my Ridgeline and my wifes Element. I intend on setting the cruise and let the computer control the shifting, unless someone can tell me that I should do something different,
Thanks in advance for your thoughts and comments
Joe
Joe
