Transmission noise help FIXED update!
MHi, any thoughts?
Started hearing like a whooshing sound that morphed into like a rattle noise. Put about 200 miles on since first heard and basically can only reproduce when accelerating in virtually any gear. If i drive it siftly no noise only if i accelerate harder and then more throttle to full no noise. It sounds like a rattle, marbles in sheet metal. Full throttle from 0 no noise..shifts fine all times.
175000 miles
Tb water at 150000
Loosened drive belt checked all pulleys and tensioner all ok
Checked all the heat shields as i was hoping, all great and tight, no rattles no leaks
Dump fluids yearly tranny fluid loks like new
Original radiator, no coolant level changes, blue as new from tb job.
No overheat, fans all work
Visual underneath all good all rubber axle boots clean and good.
I did have p420 code reset but i have been doing that when it comes on periodically for 50000 miles..about 5 times ayear...
No reverse drive issues..or excessive clunk
I did try to duplicate noise in just first gear..could not
Any thoughts before i take to dealer? Damn thing drives like new, i hope tranny ok..
Thanks!!
MHi, any thoughts?
175000 miles
Tb water at 150000
Thanks!!
