UPDATE UPDATE: Read on, there may still be a solution for this.
UPDATE: turns out this won't work. All the Nav DVDs have the code for each model: Ridgeline, MDX, RL... on the same DVD. When you pop in the DVD it talks to the head unit and sends the appropriate code so even popping in a MDX DVD would still upload Ridgeline code. Oh well, back to square one of complaining to American Honda, squeeky wheels get the grease
Making a new thread for this as I think it's an important developement. Below I've copied the messages about it from another thread.
csimo:
The Ridgeline uses the EXACT same nav hardware as a 2005 Acura MDX and RL (it is a completely different system than the Accord, Pilot, TL, TSX, and Odyssey have). The current DVD version for the MDX and RL is 4.13a. The Ridgeline uses DVD version 4.20.
If you were to put a Ridgeline DVD into an MDX or RL it would automatically upgrade to version 4.20 and DISABLE the trip computer.
If you put a version 4.13a DVD into a Ridgeline it will tell you "incorrect version" because you can't go backward in versions without getting the service department involved.
You need to have the service department enable the nav unit for a backwards revision. Once the unit is wiped clean you can then load DVD version 4.13a from a MDX or RL and the trip computer SHOULD be enabled.
So the bottom line is that you need a cooperative service department and a DVD from a 2005 (2004 and previous won't work) MDX or RL. Don't count on burning a copy because it just won't work.
If you accomplish this you can't put the Ridgeline 4.20 DVD back in the unit or it will automatically upgrade and disable the trip computer.
vertrkr:
My DVD version is 4.13a although hondanavi.com says 4.20 is the latest and only version shipped with the Ridgeline, guess I got jipped on that too. Basically I need a DVD in there so if it did update with someone's elses borrowed DVD I still have to put my original DVD back in so either it will reject it because it's a lesser version or update the firmware again disabling the trip computer. So, then I guess at this point my only option is to fork out $185 and buy a MDX DVD when they release a new version higher than what I got and then I can keep that one in. So I guess I'll wait it out until then. Hopefully Honda will see the light and re-enable on their own otherwise I'll just hold a grudge and fork out the dough so I can get the damn thing.
csimo:
vertrkr:
