Good Afternoon!
I started my 2006 Ridgeline truck this morning with no problem. My idiot light for low tire pressure has been on this week from the cold drop we had here in Ontario so I decided to put some air in the tires. I ran the truck for about a half hour while I used a 12v air compressor.
I then shut the truck off and turned it on again to see if the tire idiot light needed to reset on start. I also unplugged my 12v air pump at the same time as I was starting it. The truck didn't seem to like this.... The ignition made a click, all the normal lights came on, but no sound as far as starting.
When I tried again, I get all the lights, but no other sound.
Battery is great and I still seem to have power to everything.
I am guessing a fuse blew, but I am not sure.
Here is what I have tried so far.
Different key.
Let it sit for an hour
Swapped the start relay with the rear window relay.
Pulled interior fuses 2,18 and 21.
Inspected larger external fuses 15 and 17
Is there another fuse somewhere that might do this? I am getting absolutely no sounds from the starter at all..not even a click, but all the ignition lights seem normal.
Suggestions are most welcome.
Different key.
