1 - 15 of 15 Posts
I purchased a 12x36 x 3/8 HDPE sheet online for about $20.
I cut it lengthwise using a jigsaw with a Bosch plastic cut blade. Then I cut the 3 pieces with a miter box set to 10 degrees on each side so the bottom length is 15 1/2 inches and top comes out approximately 17 inches.
The bottom ends are rounded and beveled a little because the lower part of the slot is tapered.
That looks great. Is strength the main advantage of the HDPE over the plastic Honda OEM inserts? The cost seems to be about the same for 3 pieces to duplicate the OEM setup.
I have only seen pics of the oem dividers and they don't look as strong to me.
One sheet was enough to make all 3 so the total cost was $20.
That makes total sense. Nice job, thanks for sharing--another mod I might be able to accomplish.
Discussion Starter #8
Amazon - Seaboard Light High Density Polyethylene Sheet, Matte Finish, 3/8" Thick, 12" Length x 36" Width, Black
J21SSI, how high are the dividers? 6 in, half the HDPE sheet? Thanks for a great custom solution that's far more durable then the OEM product! :smile:
Thank you for posting. I made mine today. I made mine taller (9.75" height) which made the width 18.5" wide (instead of 17" wide at 6" height). . The bottom was still 15.5". At 9.75" height, the spare tire tray clears. Also drilled finger holes in mine.
Thanks to J21SSI for the great idea! I followed his lead a bought my HDPE on Amazon and cut with a table saw. Today I drilled finger holes and routered the edges for a smoother look and feel. Very pleased! Thanks again J21SSI!
Looks Great. Better than OEM.
1 - 15 of 15 Posts
