1 - 20 of 79 Posts
TheRidgester said:
The drill hole size of 3/16" shown in this TSB is pretty small for a drain hole.
I wonder where the water enters above the rubber sound block and if debris can also enter and eventually plug this small drain hole years down the road and cause the problem again.
My s/n falls within the TSB vin numbers shown.
I haven't had any leaks yet but finally had a couple good rains. I'll bet that there is water building up above that rubber sound block and will eventualy spill over onto the passanger side floor.
That might explain why I haven't seen any leakage yet after a few rains and washings.
Boy, am I getting paranoid or what? :eek:
TSB on front compartment water leak
I have been concerned about the potential for water leaks since before I made my RL purchase.
It is beneficial that Honda has issued a TSB on the front compartment water leak. However, I am not confident that this TSB will correct all front compartment leaks.
Over months of reading many posts regarding an assortment of Dealer solutions to this problem it appears that there are various causes for the front compartment leak. The Honda TSB only proposes one solution which I doubt will address all causes for the leak.
Example: http://www.ridgelineownersclub.com/forums/showthread.php?t=693&page=15
My S/N falls within this group :eek:, and after 4,800 miles my interior is dry. However, it may be just a matter of time before the leak starts :mad:.
I have read that individuals have been able to negotiate their own compensation ... ie, free extended warranty, free RL replacement, $$$. However, the success of this may be a function of the negotiator, Dealership, and Honda Regional Rep ... too many variables to satisfy me.
In the past, has Honda provided 1st year model owners (as a group) with compensation for the "1st year model mfg bugs" aggrevation, pain, suffering?
I know about the Lemon Law, but I'm not sure that repeat visits for a water leak caused by different problems is eligible.
Re: TSB on front compartment water leak
JimVickers said:
I have been concerned about the potential for water leaks since before I made my RL purchase.It is beneficial that Honda has issued a TSB on the front compartment water leak. However, I am not confident that this TSB will correct all front compartment leaks.
I agree 100% regarding this TSB not revealing the whole problem.There was a post from a member who went to a wedding and it rained hard while his RL was parked. When he drove away water spilled on his feet from under the dash. Now, how could that have come from a leak in just the right A pillar, isn't there a sound block also in the left A pillar? What about all the leaks in the rear area possiblly from around the top rear brake light trim piece or rear window?
Thanks for the enlightening information regarding truck trading. I sure wish I had found the ROC before I purchased my RL. I would still purchased one but I would have checked s/n and build dates first.
My dealer said mine just arrived the week I purchased it 6/9/05. Later I find a build date of 04/05 and s/n (5) 17127
Ive' been reading and gathering alot of info on these leaks and I'm going to raise hell with my dealer if they deny hearing of it.
Too bad HONDA isn't more forthcoming on this issue.
All said, I still love my truck.
Well, your lack of confidence is right on. My ridgeline is in today for a water leak right underneath the gas pedal. Also becasue The wiring harness on the dealer installed trailer hitch didn't work the first time I tried use it. Went to trailer my boat on Monday, no lights! they said they fixed it today.
When I dropped off the ridge this morn. I told the tech it is a leak from underneath through a seam near gas pedal.
Do you know, they didn't hear a word I said, he went word for word from the TSB. when they called to inform me the truck was ready, but found no leak after soaking the ridge from the top with a hose for an hour. I said that is because the leak is from underneath not from the top. as we speak they are looking from underneath as I told them to in the first place.
I hope this helps others to be specific about the location of you own leaks.
I'll update after the next big puddles I drive through
Still no water here and I like to drive through the big puddles during rain storms, last time I think I soaked three rows of cars on the other side of the highway, yes I know how bad this is, but I can't help myself and they weren't moving anyway since they were in stop and go traffic. I keep checking, pulling up my carpets (pulled out the mats and put carpets in, the carpets will being going inside soon because of the winter) and feeling under them. One time I thought it was a little damp but that was probably because my wife had water on her boots when she got in and I really mean just a little.
As to what Honda will do long term for the crazies that bought year 1, well we all knew what we were getting into when we bought a first model year vehicle. Even if it is Honda it is still year 1. I doubt they will feel any obligation to compensate us in anyway. I also have faith that they will at least keep us covered for as long as first year issues continue to crop up.
ladyridge said:
Wow...Joe..did you ever delete that fast. :)
Wow, your fast!!! Thought I deleted that earlier post within 30 seconds. :)
I deleted that post because after reading the TSB I wanted to make additional comments on what I think might be an inadequate size drain hole to drain water that SHOULDN'T be there in the first place.
I'm really pissed now, the more I think about it. They're going to drill two holes in my truck - paint them so they won't rust - and cover it all with some goop.
What a Mickey Mouse way to fix something!!
I'm going to demand my dealer to show me where the water is entering and tell them to FIX IT THERE!!!
What about other leak points that could occur on the left cabin side, or who knows where? Am I going to have a $35,000+ new truck drilled full of holes? They're attitude and fixes, IMHO are RIDICULOUS. They need to do a recall and get then ALL fixed. Why wait for wet carpets and our anxiety and apprehension waiting for a leak to happen?
Sorry for the yelling. I'm going to stop reading these Water Leak posts, they're causing me high blood pressure. Damn I'm pissed after looking at that TSB again.
I probably should of sent this to Dear Honda.
P.S. I still love my truck and want to keep it.
I haven't found any leaks yet -- but my truck falls within the VIN range on the TSB. I have to take the truck back in for a refix on the steering wheel creak and another noise, so I asked the service advisor if the dealer would like to save themselves time and money and just do the fix now for the water leak as shown in the TSB.
The service advisor was surprised, first of all, that I knew of the TSB (maybe 'cause I'm "just a girl"), and then he told me that generally they're supposed to be able to replicate the problem before they do the fix. I told him that plenty of people on this site have had the problem, etc., etc., and that hosing it down won't create the problem, and my truck falls within the VIN range clearly stated on the TSB, and he finally said that he'd go ahead and do the fix for me.
So we'll see what happens on Monday when I take it in.
Thanks again to all those here who have posted the actual TSB's!
I'm a little suprised the only fix is a drain hole. I would think water should not be getting into that area between the panels in the first place. There's about 20,000 falling into that VIN range but I suspect not all have the leak issue, I fall in the VIN range but haven't had a leak yet but I don't recall driving in rain for extended distances either so I'm still worried. I'm really hoping it's the seam filler goop robot that missed on occasion for the seam behind the wheel well but Honda can't pin point it to specific VINs so they just called out a broad range. Still I think Honda should fix the source of the water not just fix where it exits. First hard rain storm I'll suck it up and drive for a while and see what happens.
The robot ran out of goop before anyone caught it. Must not be a goop out alarm.
shovelhd said:
Woop woop no goop
You make a very good goop alarm, perhaps Honda will hire you to be the goop alarm and then you can get employee pricing ;)
***** :p *****
My VIN also falls within the range, its at the upper limit but still within. I have had no leaks (I just ran outside to check) and it has been raining for the last 4 days (I have been driving it also)
I guess I could pull the clip mentioned and poke a small hole above the sound block to see if any water leaks out. Maybe the windsheild is letting water run down, but I have no wind noise.
Maybe I can pull the front wheel off and check for places that water could enter, but like I said I have no water inside.....yet.
Who knew, mine is #219, not sure that’s a good thing but I still love the truck.
I had the sleeping robot snot fix under the fender done on mine 3 months ago; it’s been dry inside ever since. I have driven in what I would call heavy rain 3-4 times and its still dry....?? When it’s raining I take the truck out of the garage and park outside also...(test)...always dry.
Interesting part........poor mechanics get paid crap for this, no wonder dealers are in no hurry to point out Tab’s and warranty stuff.....they get paid a 1/2 hr. If you figure how much time they spend on drop off, pick up and getting the truck from the lot into the shop and back........1/2 hr is almost gone before anyone picks up a tool.
Would be nice if this was the only leak, sadly, its been good for me but sounds like others are perhaps still in the GREY zone....!!
This TSB seems to be not very non destructive and I really don’t think it would hurt anybody’s truck to have it done....some are over reacting IMO.
Good luck folks.,,.......it could be worse, you could be driving something other than a Ridge.
farmguy said:
Is anyone aware of a TSB for the REAR compartment leak?
It appears from the last page of the Trouble in Paradise thread that there has not been a resolution to this one yet.
Hey farmguy,
I've got that problem, still no resolution yet. I can only get it to leak when it rains. Haven't been able to get back to the dealer yet. I haven't heard of a TSB yet. I will post something once I find out. It might be at least a couple of weeks away.:cool:
Bought mine in May 2005, it falls within the range and boy does it have the leak. When I pulled the carpet back on the passenger side, it was multi-colored from staining. The truck stinks too, to the point where I can hardly drive it. Parts are on order but who knows if this will solve all related problems especially those that might surface down the road.
Very disappointing.
1 - 20 of 79 Posts
