1 - 20 of 20 Posts
The dealership read me the TSB on hooking up anything to the reverse lights of our Ridgelines. Honda says that the wiring and fuse is not large enough to power anything else. So what are these people with back up cameras and trailers with surge brakes going to do?
I don't remember seeing a tsb here, take a look here...
It's TSB #05162005 dated May 2005
I haven't seen the full text of the TSB, but I assumed it was the TSB to fix the problem with the factory harness not using the back up lights, not that you couldn't use the backup lights to trigger off of.
I haven't seen the full text either. I was just responding to lowriders comment that he hadn't seen a TSB on concerning the reverse light problem in the tow harness.
Both the Honda Back-up camera, and the factory trailer hitch wiring have separate harnesses, so they would not 'feed' off of the back-up light wiring or fuse. And "surge-brakes" as I understand them to be (my personal experience) are activated by "travel" in a telescoping trailer tongue. Electric trailer brakes would be another story, but again, they would be fed via the factory hitch harness, which I believe all Ridgelines are wired with (am I right on that one?).
Don't try to feed trailer reverse lights from the backup lights and don't install aftermarket high wattage reverse lights unless you use a relay.
As I understand it some people tried to splice into the backup lights and feed it though the trailer connector for reverse lights on trailers which was blowing fuses.
The TSB has no effect on the backup camera. As for surge brakes they are mechanical and electric trailer brakes have thier own circuit and are triggered from the brake lights, thus the TSB doesn't affect trailer brakes.
Drum surge brakes need no electrical connection but disc surge brakes do. Because disc brakes work equally well in either direction and backing up, especially up a slope, activates the brakes, a solenoid is required lock out the brakes in reverse. The reverse wire activates the solenoid. Without the lockout, disc brakes can lock the wheels backing up.
Reactions: Bigguy49
Thanks Webwader - I just learned something.
I know Honda made a running change at the factory to fix this but I have no idea when it was made. I do know it required a change to the main wiring harness that ran from the front to back. To fix this, to get power to the reverse pin, would require that whole harness be replaced which I'm not sure is even possible and don't know of it being done for anyone.
For what it's worth I tapped into the reverse light wire to power my doppler radar backup sensor but I have no idea how many watts it consumes. After 9 months it's still working just fine, no blown fuses yet.
Re: TSB
I hope this wont shock but help you on your tsb search.
Technical Service Bulletins - Search Results
Report Date : May 31, 2006 at 03:23 AM
SEARCH TYPE : VEHICLE
YEAR : 2006
Make : HONDA
Model : RIDGELINE
Make : HONDA Model : RIDGELINE Year : 2006
Manufacturer : HONDA
Service Bulletin Num : 06012 Date of Bulletin: MAR 22, 2006
NHTSA Item Number: 10019821
Component: STRUCTURE:BODY:DOOR
INNER DOOR HANDLE CABLE END CLIP. *TT
Service Bulletin Num : 1205 Date of Bulletin: DEC 16, 2005
NHTSA Item Number: 10018873
Component: ELECTRICAL SYSTEM
SRS DIAGNOSTIC TROUBLE CODE 81-64. *TT
Service Bulletin Num : 05045 Date of Bulletin: NOV 17, 2005
NHTSA Item Number: 10017503
WATER LEAK AT RIGHT FRONT FLOOR. *TT
Service Bulletin Num : 1105 Date of Bulletin: NOV 16, 2005
NHTSA Item Number: 10018258
VTM-4 FUSE #4 BLOWN AFTER TRAILER HITCH INSTALLATION. *TT
NHTSA Item Number: 10018262
Component: ENGINE AND ENGINE COOLING
ENGINE OIL LEAK(S). DEALER VISIT REQUEST. *TT
Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005
NHTSA Item Number: 10018482
TAKING THE MYSTERY OUT OF THE MAINTENANCE MINDER SYSTEM. *NM
Service Bulletin Num : 805 Date of Bulletin: AUG 16, 2005
NHTSA Item Number: 10016775
NAVIGATION SYSTEM SOFTWARE BUG CAUSING THE CLOCK TO RANDOMLY CHANGE THE DISPLAYED TIME. *TT
NHTSA Item Number: 10016776
Summary:
WIND NOISE AT A-PILLAR. *TT
NHTSA Item Number: 10016778
Component: ENGINE AND ENGINE COOLING:ENGINE
ENGINE OIL LEAK(S) - DEALER VISIT REQUEST. *TT
NHTSA Item Number: 10016779
Component: STRUCTURE:BODY:BUMPERS
BUMPER PAINT DEFECTS - DEALER VISIT REQUEST. *TT
Service Bulletin Num : 05033 Date of Bulletin: AUG 13, 2005
NHTSA Item Number: 10017634
Component: VISIBILITY:GLASS, SIDE/REAR
REAR WINDOW WILL NOT OPEN OR CLOSE. *TT
Service Bulletin Num : 08012005 Date of Bulletin: AUG 01, 2005
NHTSA Item Number: 10018003
TROUBLESHOOTING A STALLING ENGINE? TAKE A SNAPSHOT WITH THE HDS. HONDA SERVICENEWS. *TT
Service Bulletin Num : 705 Date of Bulletin: JUL 16, 2005
NHTSA Item Number: 10018078
DIAGNOSE ENGINE STALLING WITH ONBOARD SNAPSHOTS. *TT
Service Bulletin Num : 07012005 Date of Bulletin: JUL 01, 2005
NHTSA Item Number: 10018020
Component: AIR BAGS
CAN I TOW A 5TH WHEEL TRAILER BEHIND A RIDGELINE? HONDA SERVICENEWS. *TT
NHTSA Item Number: 10018022
Component: LATCHES/LOCKS/LINKAGES:DOORS:LATCH
POWER DOORS LOCK BY THEMSELVES OR CYCLE TWICE. HONDA SERVICENEWS. *TT
Service Bulletin Num : 05029 Date of Bulletin: JUN 28, 2005
NHTSA Item Number: 10017609
Component: STEERING:WHEEL AND HANDLE BAR
A CREAKING SOUND WHEN PUSHING OR PULLING ON THE STEERING WHEEL. *TT
Service Bulletin Num : 060105 Date of Bulletin: JUN 16, 2005
NHTSA Item Number: 10018164
POWER LOCKS LOCK SELF, CYCLE TWICE TO LOCK. *JB
Manufacturer : HONDA s
NHTSA Item Number: 10018166
Component: STRUCTURE:BODY:ROOF AND PILLARS
REAR ROOF TRIM REPLACEMENT. *JB
NHTSA Item Number: 10018172
Component: TRAILER HITCHES:FIFTH WHEEL ASSEMBLY
CAN A 5TH WHEEL TRAILER BE TOWED.*JB
NHTSA Item Number: 10018173
TONNEAU COVER WATER AND DUST LEAKS. *JB
NHTSA Item Number: 10018174
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
NO SOUND FROM DVD IN VEHICLE ENTERTAINMENT SYSTEM. *JB
NHTSA Item Number: 10018178
ENGINE OIL LEAKS. *JB
NHTSA Item Number: 10018182
Component: OTHER
BUMPER PAINT DEFECTS. *JB
NHTSA Item Number: 10018187
Component: STRUCTURE:BODY:TAILGATE
TAILGATE DOES NOT OPEN SWING MODE. *JB
NHTSA Item Number: 10018198
CRANKS, WON'T START OR INTERMITTENTLY CRANKS, WON'T START. *JB
Service Bulletin Num : 05015 Date of Bulletin: JUN 03, 2005
NHTSA Item Number: 10017510
TAILGATE IS HARD TO OPEN IN DROP MODE. *TT
Service Bulletin Num : 06012005 Date of Bulletin: JUN 01, 2005
NHTSA Item Number: 10018025
Component: SERVICE BRAKES, ELECTRIC
Summary:
INSTALLING AN ELECTRIC TRAILER BRAKE CONTROLLER. HONDA SERVICENEWS. *TT
NHTSA Item Number: 10018026
BACK-UP LAMP CIRCUIT CAN'T HANDLE ADDITIONAL LOAD. HONDA SERVICENEWS. *TT
Service Bulletin Num : 05162005 Date of Bulletin: MAY 16, 2005
NHTSA Item Number: 10016295
ENGINE-CRANKS WON'T START, IMMOBILIZER LIGHT FLASHES. *SC
NHTSA Item Number: 10016304
ACCESSORIES-BACK UP LIGHT CONNECTION IN TRAILER CONNECTOR/THE 7-PIN TRAILER CONNECTOR DOES NOT SUPPORT BACK-UP LIGHTS, EVEN THOUGH THE CONNECTOR SCHEMATIC MOLDED INTO THE CONNECTOR COVER SAYS BACK UP LAMP. *SC
Service Bulletin Num : 05012005 Date of Bulletin: MAY 01, 2005
NHTSA Item Number: 10016316
CHECK FUEL CAP MESSAGE IN ODOMETER DISPLAY OR MID. *SC
NHTSA Item Number: 10016317
CAN I FLAT-TOW MY VEHICLE BEHIND A MOTORHOME? *SC
NHTSA Item Number: 10016319
Component: FUEL SYSTEM, OTHER:STORAGE:FUEL GAUGE SYSTEM
REWRITING ODO DATA ON A NEW GAUGE CONTROL MODULE. *SC
Service Bulletin Num : 405 Date of Bulletin: APR 16, 2005
NHTSA Item Number: 10016345
Component: OTHER
CAN A RIDGELINE BE FLAT TOWED BEHIND A MOTORHOME? HONDA TECH LINE SUMMARY. *TT
service Bulletin Num : 405 Date of Bulletin: APR 16, 2005
NHTSA Item Number: 10016353
TRANSFERRING ODOMETER MILEAGE AT ODOMETER R&R. *TT
Service Bulletin Num : 05017 Date of Bulletin: APR 12, 2005
NHTSA Item Number: 10017509
TAILGATE DOES NOT OPEN IN SWING MODE. *TT
Service Bulletin Num : 04012005 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10016336
GAUGE CONTROL MODULE DISPLAY SAYS NOT AVAILABLE. HONDA SERVICENEWS. *TT
NHTSA Item Number: 10016337
OWNERS MANUAL ERROR ALERT: AUTO DOOR UNLOCK. HONDA SERVICENEWS. *TT
Service Bulletin Num : 205 Date of Bulletin: FEB 16, 2005
NHTSA Item Number: 10015296
Component: TIRES:pRESSURE MONITORING AND REGULATING SYSTEMS
TPMS (TIRE PRESSURE MONITORING SYSTEM) WARNING AND/OR DIAGNOSTIC TROUBLE CODE (DTC) 11, 13, 15, OR 17. *TT
There is a difference between your printout of NTHSA "Service Bullitins" and what we have been referring to as Honda Technical Service Bullitins (TSBs). When Honda issues a TSB, you as a Ridgeline owner can walk into a dealership and get the work done for absolutely free at your convenience. As of now, there has only been one "recall" by Honda, which is for the Cable End Clips on the door handle and this is also considered a TSB by Honda (TSB 06-012) that has an added wording advising the owners to get the work done as soon as possible.
TSBs cover lots of things. There is one that describes pre-delivery inspection. There is one that describes troubleshooting the NAV. They are designed to help service techs perform some task more efficiently.
They are not something you can just walk in and have done, although some/most dealers will honor your request if you're under warranty since they can charge it back to Honda.
Consider the tailgate-opening TSBs. If you weren't having the problem yet
went in to a dealer asking to have the work done, they would be within their rights to refuse.
If you use the reverse light feed to trip a relay utilizing power from say the trailer harness than there is virtually no load on the reverse light circuit. You should be safe.
I can be of some help here.
I just got done wiring a backup camera in my ridgeline.
due to what is covered in this post I did NOT wire them to my reverse lights.
when I wired a backup camera into my TSX, I did wire into my reverse lights,
but not on the ridgeline.
so this is what I did:
I bought an aftermarket camera. from an ebay member named edogpro.
It was like $60 shipped to me, and it fits perfectly. I bought a tailgate
handle from an 09 ridgeline in the same paint color I have. it has a spot
built into it for a backup camera, which this aftermarket one fit perfectly into.
(well, there was a touch of sanding first, but just a touch).
anyway, on to the important part.
the camera came with a very long wire for the video. it ended in a yellow
rca plug. I used the instructions from honda that came with the attachment
kit and ran that video wire to the cab. the power wire that came with the
camera was very short, and I extended it to be as long as the video wire
using common 18g wire. I ran both wires into the cab as per the instructions.
the instructions with the attachment kit are superb by the way.
so for the camera, there were 4 wires. I cut the yellow rca plug off and
separated out the two very thin wires. I also stripped down the two wires
for the power. so from the camera there was:
video, video ground, power, power ground.
the attachment kit comes with a sub harness that plugs into the navi unit
and runs as far as behind the back seat inside the cab. so I plugged that
into the navi unit and ran it to where I was supposed to. then I cut the
six pin connector off of the tip of it (the white one). well there are 6 wires
there. red, brown, blue, black (actually just the shielded outer wire), yellow,
and white. I tied the blue wire to the outer shielded wire (black on the other
end of the harness) together, effectively "jumpering" them. I tied the yellow
to the video power and the white to the video ground. the red to the power
and the brown to the power ground.
I used the ETM to determine which wire was which.
so basically what I just said is that I wired the camera directly into the nav
unit. or rather into the subharness for the nav unit, but same thing.
there is no need to tap into the reverse lights to wire a backup camera.
The Honda TSB is: 07-022
If you send me a request via email to the address below I'll send you a copy. I cannot send to PM requests.
Originally, the Ridgeline, official Honda, trailer jack(female) did not have a wired center pin. Honda advertised the trailer package as being 7 pin but did not provide any electricity to the center pin. The center pin is for getting voltage & amperage from the backup lights. Newer surge brake systems require connection here so the trailer brakes won't activate when going in reverse. A trailer's typical brake lockout solenoid uses less than one amp of current and the reverse lights use about one amp per bulb so the total draw, including the reverse solenoid is less than 3 amps. The fuse, on the reverse lamp circuit is much larger than 3 amps so there should be no problem.
Honda provided the proper wiring jack and harness, through a TSB at a later date.
froggy
froggy
I know this is an old post but it got me to thinking if the ckt that powers the reverse lights can in fact handle the additional current draw of installing an aftermarket backup camera system? If not, would installing LED lamps allow it or would a relay still be necessary?
Hey man, just wandering if you're still around this forum and willing to lend some points of advice? I just installed a 3rd party camera, which gets its power from the backup lights and transmits the video signal, as verified with a portable TV. However, I've been unable to get anything displayed on the stock screen, even though I followed the directions and connected the video signal to pins 1 and 2 and jumpered 3 & 4 together. I get nothing. What the heck am I doing wrong you think?
I'm all set. All done. It finally works. The reason why it took me two weeks instead of a few hours is because the OP never mentioned the fact that he was using a 6-pin connector in a 7-pin hole, skipping one pin altogether. The pictures show it, sure enough, but I didn't see that, I only followed text, which didn't mention this. So I did the rest of it two weeks ago, but that piece of the puzzle had me scratching my head for two weeks. Finally done, thanks to schwejo, who pointed this out to me and made me see the light.
1 - 20 of 20 Posts
