1 - 4 of 4 Posts
wheel problem when i turn to the lest i hear a freaking noise like something is robing on each other
i have change the rotor the breaks the lower stabilizer and the noise is still there when i turn to the left do any one had this problem i have a RT 2006
Well jack, your profile says you have a 2012 with Canadian trim. Regardless, your issue could simply be some trash between the rotor and the dust shield. Or maybe the rear diff needs to have a fluid change. I'm sure there are many other possibilities too.
Share you ownership history and maintenance history. Any mods to your truck (lift, larger tires, etc.?)
Struts? Maybe replace the cartridges. Worked for our CRV.
2104 Honda Ridgeline SE
I had a noise when turning left from a standstill. If moving there was no noise with left turns. Right turns made no noise either way. Took it to the dealer for State Inspection for which I had a free coupon. With the Ridgeline up on the lift, the noise could be duplicated by turning the steering wheel left. Noise was coming from the steering column knuckle area. Knuckle was loosened and re-torqued to spec and noise stopped. Truck felt tighter on the way home. 40,000 miles.
Note: Interior had been removed in the past for carpet replacement after a firewall leak that led to mold. It's possible this noise problem was caused by my steering column not been torqued to spec then.
1 - 4 of 4 Posts
