1 - 3 of 3 Posts
took off inside driver door panel to replace the relay but can only access the lower fuses with this panel door removed. Any suggestions on how to access the upper panel including the turn signal relay. 2006 RTL, 235k miles
thank you for any help.
as tight as it is, its actually easier from below
1 - 3 of 3 Posts
