I decided to add a couple of USB ports to my lower center console to power my phone or GPS. I was tired of the long cables hanging out of the 12V power receptacles.
I picked up a Dual USB Auto Charger at Newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16875991217
I see now that it is $17. I bought it for $8 on sale. It is good for 2A so it will power just about everything.
Many other USB Chargers will work but I suggest getting a 2 amp version that has a bezel or widening at the top to cover the rough hole in the plate.
The first step is to remove the lower center console using the instructions on this website:
http://www.ridgelineownersclub.com/forums/showpost.php?p=76398&postcount=10
The wired connectors are easily removed by finding the correct tab to compress which unlocks the connectors.
Next unscrew the plate between the seat heater switches. I put masking tape over the plastic, drew lines from top to bottom and side to side at the centers. In my case, the USB charger was 13/16” and I used a circle template to draw the circle. A Dremel tool was used to carve out the hole.
The shoulders of the USB Charger were a bit rounded underneath so I cut them back to sit the USB Charger flush to the plate.
Glue the USB charger into the plate using 5 minute epoxy. Screw the plate back in the console.
Solder wires from the USB Charger to one power receptacle. Keep the solder to a minimum so the plug will still fit over and lock. The center of the power receptacle is wired to the center of the USB Charger. The negative wire is soldered from the side of the USB Charger to the side tab of the power receptacle. Ensure that it is soldered low down on the tab.
Place the console in the truck to connect the wires to the receptacles and seat heater switches. Turn on the truck and test. If all goes well, put the console back the way you found it.
