How do I get threads that I have posted to, to show up in my UserCP?
Minor clarification on this point: You will only be able to see your last 500 posts. If you have posted more than that, I'm not sure if there is a way to see older ones than that.If you're wanting to see all your posts beginning with the newest first, select TOOLS > Find My Posts from the drop-down menu at the top of the page.
True, however if you use TOOLS > Advanced Search you have some additional options that can help you find things.Minor clarification on this point: You will only be able to see your last 500 posts. If you have posted more than that, I'm not sure if there is a way to see older ones than that.
Also FYI, you can see both of those options (see my posts & see my threads) by clicking on the magnifying glass on the right as well (above "log out").
Are you using a mobile version? It (mag. glass) might not show up on that...........
EDIT: I don't see a magnifying glass above "log out" or anywhere else. Do I need a magnifying glass to see it?![]()
Windows 7 Pro, Chrome and Internet Explorer. There's no magnifying glass here.Are you using a mobile version? It (mag. glass) might not show up on that.
In any case it's on the black horizontal stripe just below the RL pics, on the extreme right of the page. (on the 'new' version format)
The "Log Out" tag is just below it, underneath the black stripe.
That's very interesting. I'm on Windows 7 Pro (SP1), Google Chome (not explorer).Windows 7 Pro, Chrome and Internet Explorer. There's no magnifying glass here.
That didn't change anything.Just for grins, try going to the bottom of the page (left side) & switching from RidgelineOwnersClub(Full) to RidgelineOwnersClub(Classic), and then back again. See if that effects anything.
That did. Using Windows at work on a small 23-inch display with low resolution, I always maximize my browser window. Resizing the browser below about 75% of the display's width makes the search bars disappear and reveals the magnifying glass. At home, I use smaller browser windows on Safari on my 27" 5K iMac because maximizing the browser results in tons of wasted space.Change the size of the window (width), and it appears/disappears. May be related to screen size and resolution?
That put a smile on my face.... we've come so far in the past 20 years. There was a day when a 23" monitor was absolutely HUGE!...........
Using Windows at work on a small 23-inch display with low resolution, ...........
