I have a 2008 Ridgeline RTL with 16,500 miles on it. I started it up this morning to go to school and the VSA, /!\ and Engine lights were illuminated. I turned off the ignition and restarted, the same lights stayed on. The VSA off button doesn't work, and I can't run the engine past 3000RPMs.
My theory: there is a malfunction in the traction control system that makes the car 'think' that i'm loosing traction.
I called the dealer and they said they could look at it on Monday (today is Friday) which is too far away for me.
The only other idea that I have is some chip in the drive-by-wire system is busted and I need to have a new part installed. I couldn't find any TSB's related to this issue.
Edit: If I don't reverse before putting the shifter in drive, the engine light goes off
