1 - 8 of 8 Posts
My 2007 model Ridgeline comes up with a VTM-4 alarm after some minutes of driving. I got the following error codes when downloading codes to a PC at the local Honda workshop:
ABS/VSA:
91-1
68-1
Body:
B1008
B1060
B1061
At low speed the car has a low noise from the right front tier. The noise could indicate that the brakes have to be replaced.
The local Honda dealer in Norway/Europe does not have experience with Ridgeline. Anyone out there who knows what the problem could be???
2007 Nimbus Grey Metallic RTL
Do you have your original battery still in there? If so, weird warning indicators start coming up. If you do, I would start with replacing it. Even if it doesn't solve this problem you're having, you're pretty much due for a new battery after 5 years anyways.
Hope this will help, but it's pretty general in nature:
Looks like a bunch of sensors and modules all at the same time. Still thinking a worn out battery!
Yeah, the battery may well be the culprit.
Thank you for your help!!!
Is it possible to find a full list of error codes with descriptions on internett for future diagnostics. Do you have any recommendations with respect to OBD II scanner and analysis software for Ridgeline. I could want to be able to check for error codes (not only engine errors) with my laptop to save workshop cost.
Regards
Frode
Thanks.
I ll check the battery. I just bought the car one week ago.
Regards, Frode
Did you get any maintenance records with the truck? You might want to think about changing all the fluids to get a maintenance baseline. I would change the battery anyways since you don't know how old it is.
1 - 8 of 8 Posts
