Was VAS on or off?
I don't think so. The only marks on the grass were from the front tires. My fishing partner was watching and he said the rear tires never turned.Could it be because the system attempted to engage the rear tires and noticed slip and transferred all power to the front wheels which could also do nothing but slip, and really what you needed was power to all four wheels with a little slip to get it to start moving?
The ground was not level by a few inches, so the puppy was still wagging his tail.Job One for VSA is to prevent vehicle inversion. Terrain was not level. VSA says, "oh-oh, don't want this puppy to tip over, better do something...."
Maybe I should clarify that this occured at a very low throttle position. Since I was trying to get the trailer up on a pair of 2x6's (3" thick) that was only about 18" long, I just eased the throttle on. Front wheelspin occured almost immediately. I eased back off the throttle and tried it again. Same thing. Secondly, the tongue weight of the trailer is only 400 lb. and the bed was empty, not exactly what I would consider high axle load either. I don't buy that explanation. When I did engage VTM-Lock, the trailer went right up on the blocks with a very light throttle and no wheel spin at all. If it is as predictive as you say, it should have sent torque to the rear wheels as soon as it sensed slippage in the front wheels.Just because the rear axle is not slipping, does not mean the VTM-4 system is not functioning. You may have reached a stall condition at the rear axle due to the available force at the rear wheels combined with the mu of the surface (high axle load improves tractive force) and the reduced engine power caused by the front wheels slipping.
I agree with you, but also agree with he explanation you are responding to. The bottom line, I have tried to spin the front wheels on beach sand and in other soft traction situations have absolutley been unable to do so.Webwader said:Maybe I should clarify that this occured at a very low throttle position. Since I was trying to get the trailer up on a pair of 2x6's (3" thick) that was only about 18" long, I just eased the throttle on. Front wheelspin occured almost immediately. I eased back off the throttle and tried it again. Same thing. Secondly, the tongue weight of the trailer is only 400 lb. and the bed was empty, not exactly what I would consider high axle load either. I don't buy that explanation. When I did engage VTM-Lock, the trailer went right up on the blocks with a very light throttle and no wheel spin at all. If it is as predictive as you say, it should have sent torque to the rear wheels as soon as it sensed slippage in the front wheels.
