1 - 9 of 9 Posts
Hi, new to this forum as my 2019 Ridgeline let me down big time last night.
ABS, steering EPS, road departure, emission, hill start, vehicle stability warning lights all lit up. Vehicle drove ok for approx 2miles then proceeded to shift strangely and finally began to idle rough and loose power.
Has anyone had any similar problems, suggestions?
If it's still under warranty, take it to your dealer.
If it's no longer under warranty, take it somewhere that can read the stored code(s). It's not unusual for a single problem to affect multiple systems due to their interdependency. Most likely, you have an engine-related issue ("Emissions System Problem") that is preventing other systems from working properly.
A bad battery has been known to do all you describe with the lights and warnings.
Bad battery did it to me. Got the battery replaced and was as good as new
Discussion Starter · #5 ·
Really appreciate your input, dealer is getting it Tuesday
This happened to me when the squirrels ate through my wiring in my 2020 ridgeline sport.
This happened on my 2017 RTL-E when the 3rd gear transmission pressure switch failed as 38K. It was about a $200 fix and not covered by to 5/60 powertrain warranty.
1 - 9 of 9 Posts
