21 - 31 of 31 Posts
Does anyone have any experience with the weathertech roll up tonneau cover? I thought I was going to get a diamondback se, but the weathertech one seems to be aluminum slats with a vinyl covering and a lot cheaper. It is a but unclear how it installs, how easy it is to remove or how secure/waterproof it is. Any insight would be appreciated. Thanks
My wife and son bought one for my 17.. he installed it in 1/2 hour.. I've been liking it since he put it in.. no leaks that I've seen.. like you said earlier it's also much cheaper than the others
2021 black edition
Discussion Starter · #23 ·
Thanks. That helps. Did it require cutting anything or just replacing screws? How secure is it? I'm not necessarily looking for Fort Knox, but enough for a casual thief to keep walking.
I looked around a lot and ended up going with a tri-fold that looks VERY much like the weathertech tri-fold. It had free shipping, was quite easy to install with common hand tools and is made by Lomax. I purchased it from Auto Accessories Garage and shipping was about 2-3 days. There is a very small leak when going through the car wash and gully washer rain storms. I believe it occurs where the bed rail has a small 3/8" or so groove on both sides near the front of the bed (not sure what its purpose is). I am very pleased with the cover and it is easy to remove in needed. Have a look at:
Cheers.
The Weathertech is a re-branded Lomax. I bought the Lomax and used a small tab of RTV in the grooves in the top rails and have no leaks after two years.
2021 black edition
Discussion Starter · #25 ·
Good to know. So look for the better price between the two. What is RTV?
Thank you.
Obsidian Blue Pearl 2021 RTL-E
I believe all RTV will be waterproof, regardless of color (or lack thereof).
Some appear to be geared more toward high temperature applications or oil resistance, but really I think they're all pretty similar.
Sent from my Pixel 5 using Tapatalk
2020 RTL-E, Pacific Pewter
Forward tie downs CANNOT be reinstalled (these pictures ended-up in reverse order — it’s too much trouble to rearrange them here) — but you can see why they can’t be reinstalled (because of the flair in the cover bracket between the screws).
Just installed my Revolver X4s, and I was able to flip the front tie downs upside down. The brackets that came with mine didn't have that flair - unless I made a serious error installing them, which Im now going to double check though nothing flew off during a short drive.
You might be able to get for new flat brackets...?
21 - 31 of 31 Posts
