1 - 10 of 10 Posts
1st time transporting two dirt bikes for a three hour drive north in my Gen 2 RTL-E. Returning in the dark, I had several people go out of there way to brake check me or get behind me and repeatedly flash their brights at me. My brights were not on, but I think the two bikes ( combined weight at about 500lbs, mostly towards the rear of the bed ) tilted the truck bed down enough to raise the nose and point the headlights up into other drivers mirrors & eyes.
Is there any type of adjustable rear lift / airbag that help alleviate this from happening again when hauling my bikes? Any ideas will be appreciated.
Didn't think 500 lbs would make such a big change in headlight aim.some but not that much.
See if your lights are not aimed a little high already. And with the weight in the bed makes them point up more. Most of the newer headlights are super bright anyways.
The LED projectors are very bright, I get flashed on a regular basis with no weight in the back.
No, 500lbs isn't that much, but most of the bikes weight is distributed pretty far back in the bed. That seems to be the issue. I'll try to post a picture since I still have one bike back there.
As far as how bright the headlights are, I have not been flashed for bright headlights until I had the two bikes in the back. I've had the truck for around a month +.
Probably because they are aimed too high from the factory.
LED headlights on loaded pickup trucks is a problem because regulations do not require auto-leveling of the headlights.
Discussion Starter #6 (Edited)
As you can see, most of the weight is behind the rear wheel / suspension.
Looking under the truck this morning, I see no place for any airbag, etc. Maybe an air adjustable rear shock? (BTW, the truck drove fine w/ the two bikes back there.)
Or maybe self leveling headlights? (That sounds $$.)
Edit: Does the 2017 Pilot have self leveling lights? If so, think that could be a possible fix?
Contacted the dealer & they said no self leveling headlights are available for the 17 Ridgeline, no comment about rear air adjustable shocks.
This is a real thorn! I take bikes out every Saturday and w/ DST, it is dark more often on my long trips home.
You'll just have to pack-on some extra lovin', you know grow that muffin-top, start a flab-alanche, add-some laundry to you're washboard abs. Sorry I meant to say get your riding partner to get fat. ;)
All kidding aside I think they are lifting due to the bikes, cause just accelerating alone can inadvertently get in the mirrors of vehicles in front of me. I'm not much help but I know where you're coming from.
PS I just noticed the reflective tape on the side of your tailgate. Great Idea! I hope its OK for me to steal it :)
While on my fall fishing trip I had my fishing rod rack mounted in the trailer hitch with my fish coffin aka cooler in it. Constantly was flashed by on coming traffic. It is annoying but when I popped the LED high beams in their eyes they stopped flashing.
1 - 10 of 10 Posts
