61 - 79 of 79 Posts
2020 RTL
I just got my truck back after FORTY EIGHT DAYS at the dealer. The carpet they replaced is still torn, but now sewn rather than replaced, so it will go back for new carpet once that comes in. We will see how it holds up to the rain, zero confidence it is fixed, no notes or pictures provided on what was done, not assurance it is fixed, merely that is is "back from the body shop." Fed up.
Point it downhill and try to get it to leak by flooding the bed and rear window area. Keep sticking it to Honda and making it expensive for them. I know it's a pain, but we have to be persistent.
Check the lemon laws in your state. In MI its 30 days away for repairs or 4 visits for the same issue.
It sounds easy, but there's "a procedure"... :)
Of particular interest is the part that reads, "If a manufacturer has established or participates in an informal dispute settlement procedure, the Lemon Law does not apply to any consumer who has not first resorted to such procedure..." Honda participates in the National Center for Dispute Settlement.
Also, "...less a reasonable allowance for your use of the vehicle and an amount equal to any appraised damage that is not attributable to normal use or to the defect or condition."
In short, it could take months to go through the process and even then you might not get any more than if you sold or traded the vehicle.
2021 RTL-E
Discussion Starter · #68 ·
Never said it was easy, just offered the option for the other poster to consider. If my truck is in service for more than 30 days I'd be speaking with a lawyer about my options. I'm certainly not there yet and hope I won't be.
It does seem like an easy process to get done correctly. If only the folks in Alabama could be motivated to do their job with a level of consistency and dedication as expected for a $40k vehicle ! ! !
Despite the hit or miss quality of “made in Alabama”, Ridgelines leaked when they were made in Canada too. We had a 2007 leaker that wasn’t sealed properly on the driver’s side A pillar. Honda knows, and has known for far too long. Why they don’t address this issue is beyond me.
2017 Ridgeline RTS in Deep Scarlet Red
One of the strange conversations with the Honda dealer tech that fixed my RL is he's found and repaired body leaks across several vehicle makes & models where he has worked. The reference was in the context that somehow manufactures regard leakage as acceptable/normal to a certain extent, just that some vehicles become problematic. It's in the same context as when I complained about odometer error on a past Nissan, they responded that 5% error is considered an industry acceptable standard. Certainly suggested that shades of grey are common with these complaints.
Yeah, on the RAV4 forum, there are plenty of threads about stained headliners due to water leaking from the roof rails. From what I read, Toyota didn't help those with the issue but they did start to use a different clip that had a more robust gasket.
Update: not only is the truck not repaired, it is leaking WORSE than before. The padding under the carpet is absolutely drenched after it rains. 48 days in the shop, and and after one day I had to arrange to drop it off again. Nothing from Honda. Miserable experience.
Yeah - that's what happened with my 2019. The back window was leaking on the driver's side when I took it in. After it was "fixed", it was still leaking not only on the driver's side, but also on the passenger's side and in the middle. It's leaking for someone else now. :)
2018 RTL-T
And they’re probably on here posting about their Ridgeline leaking like a sieve!😁
2021 Radiant Red RTL
Honda should have sent that RL to the crusher.
2021 Ridgeline RTL-E in Radiant Red Metallic II
So it's been a couple of weeks since I got my truck back. I had the rear carpets propped up to dry until this weekend, and I looked for any new water during that time (we've had some good rain here in the PNW). I am happy to say that it appears the leak has been fixed, so in my case it apparently was a bad rear window seal. Thanks to everyone on this forum for making me aware of this issue, otherwise I may never have found it.
2022 Ridgeline RTL-E
All these posts about water leaks is making me paranoid! I have a 2022 RTL-E, OEM tonneau cover. Build date 10/21 (brand freaking new essentially). Not sure what I can do except keep an eye on it and maybe avoid any forward leaning parking. Considering preemptive open communication with the dealer here, maybe they can pre- or re-seal the known spots?
Vehicle Car Automotive parking light Hood Automotive lighting
Car Vehicle Automotive tire Automotive lighting Motor vehicle
Hood Automotive tire Grille Automotive lighting Trunk
This link was very helpful…
61 - 79 of 79 Posts
