1 - 13 of 13 Posts
I just bought a 2006 RT last week. It was my dad's and I had been driving it for about a month prior to buying.
I was cleaning out some bb's that got under the carpet and wee rolling around and driving me crazy when I noticed the carpet was damp under the right rear seat. There is no misty odor at all and nothing was recently spilled.
Any suggestions on where to start investigating the source are greatly appreciated.
Thanks!
Do you have a sunroof? (don't remember if the 2006 RT had one or not)
Chip H.
Thanks!
The only thing I can suggest is to see if the drain holes on the bottom of the doors are plugged.
Take a small stick or pipe cleaner and shove it up in there and move it around.
That link won't help as that deals with water that enter in the windshield area and drains through a drain hole witching the front mud flap.
The drains that were suggest to be checked are within the door bottoms
I know his is an older thread. I've never had any problem with leaking in the cab. It rained really hard last night. When I got in the truck and started up my hill I heard water spilling. I looked over to my passenger side floor and under the glove box area was water. I pulled over for a second and I felt up under the glove box and the wires and plastic pieces under there were wet. I didn't have time to get a good look to see where it could have came from.
Any ideas?
That's the same area my RL has leaked since new. I took it back once under warranty and they sent me to a local glass shop. They couldn't duplicate the leak. It only seems to happen in very heavy downpours and leaks a few tablespoons of water in the center of my floor liner right under the glove box. When I look behind the glove box, I can see the plumbing is wet, but I have no idea where the water is coming from.
The heavy downpours are so infrequent it is tough to demonstrate the issue. Running water from a hose wouldn't duplicate the issue. Fortunately, my floor liners contain the water. I've never noticed any wetness of the carpet, front or back.
2104 Honda Ridgeline SE
The most common sources of leaks tend to be...
Roof rack attachment points under tracks in roof exterior.
Body plugs/grommets missing from delivery tie down holes on side rails under truck.
Front windshield drains to bottom of front mud flaps.
Rear sliding window.
Door drains.
All of these have been discussed on the forum in the past and can be found using the search option.
Good Luck.
That's the same area my RL has leaked since new. I took it back once under warranty and they sent me to a local glass shop. The couldn't duplicate the leak. It only seems to happen in very heavy downpours and leaks a few tablespoons of water in the center of my floor liner right under the glove box. When I look behind the glove box, I can see the plumbing is wet, but I have no idea where the water is coming from.
The heavy downpours are so infrequent it was tough to demonstrate the issue. Running water from a hose wouldn't duplicate the issue. Fortunately, my floor liners contain the water. I've never noticed any wetness of the carpet, front or back.
Yeah this has never happened before and like you said it was just a few tablespoons right in the middle of my weathertech mats.
Very strange.
Door drains.
Good Luck.
I checked all these last time I washed the truck to make sure none were clogged before winter. I seen they were problems before on here. But I had never seen a post about it leaking under the glove box on the passenger side until I did a search on Google.
Very strange.
Well if you find the leak, it will probably be the same issue that only rarely shows up on mine. And vice versa.
If my issue was a blocked AC drain, I'd see it whenever I run the AC. I only see it it in the heaviest downpours.
1 - 13 of 13 Posts
