1441 - 1460 of 1500 Posts
Learned something new about the RL today. I have a slow leak on one of my tires, lost 6 lbs in 24 hrs. Backed it out of the garage and left it running while I grabbed the air compressor hose and pressure gauge. Started adding air to the tire and it beeped at me. As I got closer to 36 psi the beeps became more rapid. Stopped and checked with the gauge, right on 35 psi. Hard to believe but this is the first time I ever had the RL running and added air. Cool feature if you ever have a low tire and forget a pressure gauge.
2022 RTL-E (Radiant Red), 2013 RTL (Dark Cherry Pearl)
Tinted the fronts 20% ceramic, clear bra lower front, black plastic door handle covers, remove chrome emblems on tailgate and replace with black. Now to that damn shiny chrome RTL-E window trim and the chrome "brow".
21 Platinum White Sport
pic of the door handle covers?
Brand off LED Hight Beam please
Some folks on this forum say these are plug and play, but I had to file down the tabs a bit for the passenger side fitment on my 2022 RTL-E. Took me 15 mins of sanding and test fitting, but got it to work. Light output is impressive.
AUXITO brand.
2022 Sonic Gray Pearl RTL-E
Pro Truck cargo dividers and aftermarket SportWing door ding protectors.
Are the Sportwing Protectors mounted in the same position as the Honda ones?
2022 RTL-E Crystal Black Pearl
No, they are not...totally different design and mounting position.
Reactions: Sparkland
I had them on my G1 and there was only one per door, as opposed to the two that the OEM BSM's had. Now that you mention it, I see that the Sportwing's are mounted higher on the door.
I have used Sporting before on several other vehicles. Great quality and always seem to be designed as a more generic moulding that mounts near the center of the door.
Mine were hard to get in on my 2019. I ended up putting a little lube on the orings as they were sort of dry and a bit bigger than what was on the original bulb. That made it quite a bit simpler.
hauled an old queen mattress and frame to the dump.
You have a 'dump'? Lucky you.
[/QUOTE]
Our landfill charges you plenty to take a mattress to the landfill: $59 on top of the $142 that they normally charge for a pickup load. No wonder you see so many mattresses on the side of the road on the way to the landfill.
  • Wow
Reactions: WB77
I put a retrex on my 2021. Pricey but I like the look, the convenience and security.
Nothing beats a Retrax. I’ve had 3 of them.
2019 RTL awd, MSM
[/QUOTE]
Here are our fees.... not sure what mattress would fall under. Probably construction debris, at $12 + tax.
I love our town dump. Single stream recycling, they take metal, $100 for 52 punches or about 1 punch per 40is gallon bag. I've never even used half of the punches each season in the 10 or so years I've been doing this. I think the composting and recycling we do results in a lot less garbage. They take motor oil,coolant, oil filters and all lawn debris. Tires are pricey at 18 each for anything over 18 inch I believe. All other demolition stuff they have been reasonable with charges.
By contrast, garbage service was $45 per month when I used it.
