1 - 4 of 4 Posts
I was curious what the maximum speed was in each gear, so I calculated the folllowing speeds. I used 6,250 RPM and a static loaded tire radius of 14 1/8".
Since I was doing the calculations, I also included the overall drive ratio to the rear wheels.
Gear Max. Speed Overall Ratio
1st --------38----------12.207
2nd--------66------------7.099
3rd--------101-----------4.637
4th--------142*----------3.305
5th--------196*----------2.407
* Theoretical only - limited by speed limiter and horsepower
In a previous thread, someone wondered why the RL doesn't shift into 5th at speeds lower than 47 mph. If the shift occured at a lower speed, say 40 mph, the engine would only be turning about 1270 rpm.
I doubt this truck makes enough power to get to 142mph, especially sicne it isn't areodynamic. My 89 mustang could only muster 135mph in stock form.
All Honda’s have fuel cut to prevent over-revving the engine. The shift point in manual is actually a little different at max throttle than in “D”.
The top speed is limited based on the tire specs.
1 - 4 of 4 Posts
