1 - 6 of 6 Posts
I've noticed this button on several RL's, it is usually added in this general area.
I know it's a aftermarket item, but what is it for? None of the RL's have any other exterior lights that I can see.
Thanks
You sure it's a button? It looks like a security light.
Good point Ourfarm09, it could be.
I've seen them mounted on the switch panel and even higher by the light switch.....hmmm.
Looks like security light using blank.
When l had aftermarket alarm installed on my Acura when new they used that blank for security light and valet/anticarjacking code buttons. Would this bemail a newer than 2007 Ridgeline? I see VSA and Fog lights switch using two spots. On 2007 they have master cruise control in onerror spot VSA and if you installed fogs the 3rd space.
I forget the year the moved master cruise switch 2009?
Correct FTM1, 2009 & up. I've noticed this light/switch on several 09'-11' RTL RL's.
An aftermarket doodad for sure.
1 - 6 of 6 Posts
