1 - 20 of 24 Posts
I found this in my driveway. Is it from my RL, or did the wind blow something out of my neighbor's yard? No recent work done...
It looks like flappers for inside air, guess I'll go look underneath to see if I can find where it goes.
(I'm not used to parts falling off!)
400608
400609
Discussion Starter #2
Nevermind, found it!
400611
Weird - any idea what might have caused it to fall out?
No, but I bent the 6 retaining tabs out a bit to hopefully ensure it does not reoccur. It clicked into place and seems very secure. It does not budge when I pull on it.
400612
2018 RTL-E
I can’t tell from your picture where it goes. Is that on the rear of the cab, maybe an exhaust vent?
It is actually the right rear underside. When it was out, I saw the spare tire. You can see it in my second post, the "Nevermind" post.,
2018 RTL-E
Ok, I enlarged it and can see the spare. I guess it’s a vent for the trunk.
I’m wondering, you must have a heck of a driveway curbing to bounce that over the tailgate.
Just one more unexpected benefit to having a bed cover! :/
Discussion Starter #9
No curb at all, that is why it's strange, AND, I have a Peragon Tonneau. How would that help? This is only accessible from underneath the truck. It's above and inboard from the right rear wheel.
Discussion Starter #11
I'd guess a part which should have been replaced during your accident? I think I'd order or find the part number and maybe keep an eye on it, incase you have to order it
My mistake, I was apparently confused as to where this came from.
sorry for any confusion
Ah, yes, I'd forgotten about the accident. Good catch @Carsmak & @14v6, I agree likely a delayed odd residual of that episode.
And yeah, lucky for @HyperPete it finally fell in the driveway! Bet it 'stays put' now that it's been properly 'clicked home'.
That part is similar to the one in the 2004 Civic that causes the trunk to fill up with water when the seal around it fails. I had to chase down a water leak once on the Civic.
Discussion Starter #18
I did think about the accident possibly causing the problem, but the hit was in the left front. I have also put a lot of miles on the vehicle since then, including many trips. I'm thinking that it just was not ever seated properly when the vehicle was built, and it took 45,000 miles to jiggle free. While I don't know how or why it would fall off overnight while parked in my driveway, I'm grateful that it did, because it probably isn't inexpensive.
I am going to pull out the spare just to ensure that it did not blow out for some reason. That is the only thing I can imagine that might have forced the piece out. Maybe I will even use some silicone from the inside to further seal it in place. But I think the best thing to do will be to relax and have a beer! (This evening, however!) 😁
Is it possible that sliding the spare tire tray in or out could have "bumped" it from the inside? That's the only thing I can think of that would push it out. Did you mess with the spare tire at all lately?
Probably not seated properly from assembly. Their are a few old threads of people complaining about dust in the trunk, they were missing this same cover.
1 - 20 of 24 Posts
