Guys,
I purchased a 2007 Honda Ridgeline. No idea on the service that's been done to it. I changed the transmission fluid and I am going to change the VTM fluid.
Should I change the spark plugs? I never changed the plugs on my 2003 Toyota Camry that had 180,000 miles and it ran like new when I sold it. Not sure if Honda plugs are as good?
Next up the timing belt and water pump. Should they be replaced if so can you direct me to a sticky for that.
After looking at your site I read about the transmission line problem where they attach to the radiator. I will look at those.
I did change the air cleaner.
Any advice would be good. Thanks
