121 - 133 of 133 Posts
You are the first person to ever notice that "missing" hose. Just kidding, everyone asks the same question. It is designed like that and your truck is fine.
Reactions: zroger73
Reactions: zroger73
It's a logical question.
Reactions: scubacamper
I am a new owner of a 2006 Ridgeline with about 200K on it. After I took out my old battery to replace it with a new one, I noticed that there was a loose 1/4" tube at battery's 10 o'clock position. The inner diameter is about 1/32" or 3/64" roughly. I thought I might have disconnected it when pulling out the battery. Is this a disconnected vacuum line? It is secured to the larger hose below it, but cannot see where its other end goes. Any thought is appreciated.
Thanks.
404426
404427
404428
Is there an empty breather nipple on the air cleaner assembly?
@mazamin, enjoy this thread...
Breather for either transmission or ?
Searching for the picture @smufguy
Moderator Note: Thread Merged
That appears to be totally unrelated to the transfer breather back near the top center of the firewall.
I believe this is another breather hose that should attach underneath the engine cover.
404432
404433
Agree, but we had a picture earlier in this thread which showed that one and the picture is missing, it was even nicely color coded
2010 RT - Bali Blue
Great. Thanks. What does this breather hose do?
Simple, read below. Same principle applies to the rear differential and the center transfer.
Breather assembly is mounted on transmission to maintain the pressure equilibrium inside transmission. Breather allows the transmission to breathe air when the air inside transmission expands or contracts due to heating and cooling of lubricating oil during vehicle running. Breather allows the hot air to escape and cool air to enter into the transmission to prevent overheating issue. Failure of breather assembly can lead to pressure buildup inside transmission and further leading to leakage from transmission oil seals.
- Source: sae.org
Looking back over my life which has been difficult, unrewarding, and not necessarily well-lived; maybe most of it I had little to no control over. It occurs to me, where would I be if I just had a transfer assembly breather box. Something to regulate the pressure back to atmospheric so the mechanical components can function as designed. You just have to appreciate the simultaneous simplicity and complexity of this beautiful feature, that is mounted right there for you to see as easy as popping the hood. Awareness of this relief component has allowed so many things to make sense for me right now. Not everything but better than before.
