1 - 5 of 5 Posts
Just had the passenger wheel bearing replaced. Not all the abs lights come on after you drive it down the street and it sounds like the tire is whining. Is that normal? How do u get the lights to reset?
I had a wheel bearing replaced in my 06 RL, and the garage used a non-OEM bearing and put it in backwards. That caused problems with the ABS since there is a sensor on one face of the bearing. Not sure if your issue is similar.
When the correct part is installed right, you will not have any drag or weird noise. You can use either the OEM 44300-SJC-A01, Centric 412.40023 or Timken WB000008. Same bearing part number for both sides. These parts are for the G1 (all years).
@Lgtub Year, Model are helpful to members to diagnose issues such as this...
20O6 rts
1 - 5 of 5 Posts
