According to online sources, the stock wheels on the 2017 Honda Ridgeline are 18x8 with a 5x120 bolt pattern and a 55mm offset. I was thinking about a set of BBS Rims from TireRack (see link below)
These BBS rims have an offset of 32mm which would push the new wheel outboard. Most aftermarket wheels have offsets considerably smaller than the stock 55mm. From what I've read, pushing a wheel outboard (all else being equal) is not necessarily a good thing as it increases stress and potential wear on suspension components. I also read on a professional site that in choosing an aftermarket wheel, the new offset should NOT deviate more than 5mm from the stock number.
The last thing I want to do is increase stress and wear on my vehicle. However, with most quality aftermarket rims significantly different in terms of offset, it seems like changing rims isn't a good idea. Any thoughts on this matter would be appreciated as I need some knowledgeable advice.
Below is the link to the BBS wheels I was looking at on TireRack
Thanks
Dave
BBS SR Anthracite Painted
Thanks
Dave
