1 - 2 of 2 Posts
Has anyone had trouble with their front wheel well liners coming loose? It looks like some kind of tab wore off, and the liner is pulling away from the outer edge of the fender. Looks like a trip to the dealer.
If you had the wheel flares put on at the dealer, it makes total sense.
They left bolts out on mine, causing the wheel liner to pop out often.
Look at & see if all the bolts are in place. If your not sure, like I was not..I went to the dealer and parked next to another ridge & noticed what mine did not have in place... easy enough then to prove to the service rep... good luck with this
1 - 2 of 2 Posts
