Who has purchased a Bed Step?
8354 Views 29 Replies 16 Participants Last post by  TommyG
I recently purchased a bed step on Realtrucks.com, it was manufactured by Lund, however, where the hole is on the piece that fits into the 2" hitch assembly is so far back on the receiver of the step, the step sticks out way to far from the hitch assembly for my liking. Has anyone here purchased one that they really like! Could you post a pic if you have one that you think looks good and where you purchased it.
Thanks.
1 - 20 of 30 Posts
I haven't bought one because if you swing the door open to the left, the license plate area becomes a step effectively. But I just saw this one on the WEatherTech site a few days ago and thought it looked pretty good.
Bump Step Hitch Step - Trailer Hitch Mounted Bumper Protector | WeatherTech.com
Reactions: 1
I got one that lights up with my lights!
Reactions: 1
Where did you get that? How does it connect up?
2
I bought this one from Real Trucks but I had a hole drilled into it so it fits snug up against the hitch
Same problem that I am having with the Lund one....but the receiver piece is about 1/2" thick and hole would be a bitch unless done with a plasma cutter....is possible! But I like the one "timbotc" has with the lites....where did you get it!
While I can't tell from his picture it could be this one:
https://www.amazon.com/Bully-BBS-1104L-Black-Bull-Hitch/dp/B006PPM6CO
Reactions: 1
Pep boys. It connects to the trailer hook up! You need a 7 to 4 adapter!
Did this several times today as I was washing/waxing my truck. I used the tailgate to balance.
Reactions: 1
timbotc could you send me a daytime pic so I can see what it looks like?
The problem with using the rear bumper by the license plate is it might be a possibility of plastic cracking in cold!
I've come close to buying one of these especially the NHL logo ones. Would really like to see a picture if someone else has done it.
Here's a better pic! I was away from the truck!
I love mine! >:)
Thank you Timbotc! It is the Bully...Looks good!
I have had this step for about 10 years and still looks new other than a few scuffs from others hitting it. Saved my 4Runners bumper numerous times. Highly recommend it.
https://www.amazon.com/Go-Rhino-360PS-Stainless-HitchStep/dp/B000CMH7JS
Reactions: 1
I do too. It's the easiest truck bed to get into that I've ever had or worked around. I find that I'm opening the tailgate to the side 70% of the time.
Can either one of you tell me how much "play" does the tailgate have in terms of up & down when it`s swinged out ??... mine does a little bit and I was wondering if others find it to be too much play ??...would preferred a little stiffer at the hinged area though...Thanks ! :smile:
I have one that said "CANADA"...also have an anti-theft hitch pin...will take a picture for you tomorrow. :wink:
I'll have to check and get back to you. I haven't really noticed any play, but I'm sure there is some. As you probably know, some up-and-down give is a good thing. You don't want it to be so tight that parts wear out quickly. I'll check today and hopefully post tonight — if Ridgerunner67 doesn't beat me to it.
:grin:
Reactions: 1
4
@lslick23
quick snapshots with locking hitch pin...Steps have multi-positioning holes...this is all the way in. >:)
~~~~~Oh..CANADA !!! eH ? ~~~~~
1 - 20 of 30 Posts
