1 - 5 of 5 Posts
Will these 20 inch 7 spoke Range Rover Wheels. I believe that they are 5x120 but I am not sure what the width or the offset is on them or even if they are staggered or not. Can anyone help?
Hello,
I think range rover wheels are 5x120, with around 50mm offset. I believe it should fit. I also think that the width of those are around 8.5? I am not sure of that, as I am new to this site.
I am myself looking at range rover replica wheels...but just looking! haha.
good luck!! keep us updated on your decision.
regards,
malcolm
best way to tell is with a jack and lug wrench!:D
In addition to bolt pattern, width and offset, the center hole bore can be different among different makes. The center hole is used, at least in some applications, for centering the wheel to make it hub-centric. On other cars the center hole doesn't do that and the wheel is centered by the lugs alone.
I'm not sure if the center hole is an issue between RR's and RL's.
1 - 5 of 5 Posts
