1 - 3 of 3 Posts
One of the windshied washer nozzles on my 2006 has gradually lost volume and the spray doesn't make it up to the windshield.
I stuck a paper clip in the orifice in the hope to dislodge something---no change,
taped shut the side that worked and ---no change to the bad side,
unplugged the hose connection by the base of the windshield and shot pressurized air---no change,
tried to blast compressed air backwards, not real sure anything happened with this---no change,
Ran some simple green solution thru the hose and nozzles---no change......
Suggestions?
Help
Try Soaking it in CLR, it should "Free Up" hard water deposits or just order one from your Honda Dealer or one of the many online.
Thanks
For $9 I'll just order one.
The parts diagram I saw didn't show nozzles separately. Only a complete assembly.
Know the trick to popping off the nozzle?
1 - 3 of 3 Posts
