1 - 9 of 9 Posts
Gentleman,
Would Honda OEM 18" wheels, part number 08W18-SJC-100 work on my stock 2006 RTL? Thanks.
Same bolt pattern for all 9 years of the RL so I don't see why not
2021 Honda Ridgeline EX-L Canadian
Yes they do.
I have 2013 18" wheels on my 06.
Discussion Starter #5 (Edited)
Thank you guys very much for taking the time for your input, I did not have a clue if the cross walk of wheel size and width would work, and of course the bolt pattern. Could I swap my TPMS from my 2006 16" wheels over to the 18" wheels? What would be the biggest 18" tire size/width I could run without rubbing fenders? Would these wheels show a different ground speed on my speedometer? If so, how could you recalibrate the speedo or what manual speed difference would I have to keep in mind?
Yes you could swap tpms but I would buy 4 from Honda and be done for 8-10 years. Those 06 are getting old. 265/65/18 Michelins rub a tiny bit for 5k but look great. Your speed will be +3 but a little math and you get used to it.
Your 2006 wheels should be 17" and not 16". Unless you have different wheels than Ridgeline wheels. If your 2006 wheels are steel, the TPMS sensors may be different.
2014 Sport
Don't bother with the 2006 TPMS sensors. They are just about done with their useful battery life. Buy a new set or you will be doing all again within a year. . .
I'd contact our Site Sponsor : Discount Tire, to see if you can THESE
1 - 9 of 9 Posts
