I have my Roady XT in now, but have a few questions for those in the know:
1) I am currnetly using the power plug to get my juice - Id prefer to chop off the plug and and hard wire to the back of the power outlet. Can I do this? I see the unit is 5V, and I assume 12V is running to the power outlet. Will this blow up my unit? WIll it still be ok to then use the power outlet or will I be trying to get too much from it and blow a fuse?
2) Where did you run your antenna? Out the back window? Pics would be appreciated. (Mine is out the back window for now, until I see the best way)
Thanks!
Thanks!
