1 - 10 of 10 Posts
Installed PSP and Roady XT this weekend, ill do my best to attach pics below... its not looking good so far, lemme try again...
Nice setup.
Removing the center console was not as easy as I thought it would be. If you follow the instructions for the Cigarette lighter you will be fine, with the following hints:
1) The clips between the console and the piece that connects up by the firewall pull straight out to come apart (not sideways or anything of the such) stick a screwdriver in the little slits you see between the two.
2) The "this is not an ashtray" comes out by pulling straight out - open it a bit and pull it straight out. I was trying another way - Wasn't working.
3) Don't take any shortcuts -I tried to (for some reason) pull out one of the pop-outs where the seat heater switches go - they screw in from the back.
-- All in all it looks pretty good - Ill ultimately need to get new push-outs before I turn the lease in or sell the car (just the middleone) - I scratched a few spots and broke a small piece on the side rear of the console (instead of the clip coming out). If I did it again - NO PROBLEM ! ahaah
Right now the PSP runs off of an XM transmitter. The bracket holding it is made from 3/4 PVC pipe, and covered with a rubberized front plate to hide what is behind it. The transmitter goes in before the bracket and fits well. Easy to install and remove - takes 5 seconds.
I do have a question. I currently am using the power outlet to power the XM radio - If i want to hard wire it - can I clip off the power outlet plug and hard wire it to the back of the power outlet? I am concerned that it is a 12V source and the XM only needs 5V. Any info on this? Don't want to blow it up.
-Jason
What's your favorite game to play while you're driving down the freeway?
HAHA - Gran Turismo of course. ahaha
Mainly for MP3 play, and movies when parked. (or for passengers)
That's funny, Trizzane. Welcome to the board.
How do you use the radio presets?
Green With Envy Moderator
Very nice. Thanks for posting the pics.
Discussion Starter #10
Presets : I can see the first few , and its not hard to get behind the PSP if you really want to. I only put the PSP up there if Im going to listen to my MP3's, so - I really dont use the presets when its up there. I just remove the whole thing if I want to use the radio. Also, I have XM (same frequency as the PSP is running thru) so the radio pretty much stays on that preset (#6) the whole time. (unless I need to listen to local radio for some reason - ie. weather or traffic)
All seems to be workign good so far. Just need a new, more modern XM transmitter for the PSP.
1 - 10 of 10 Posts
