41 - 52 of 52 Posts
Well, in terms of Ground Clearance, Honda put on relatively low profile tires. they could easily have gone with the 255/70/18 which would have provided another .5 to 1 inch of ground clearance. then we would be at 8.5 to 8.7 inches of ground clearance at the rear suspension mount. the Rear Diff is already at about 10 inches above the ground. Bigger tires will get you most of the way.
IIRC when Honda debuted the G2 RL at some auto show back in 2016, they originally had 265 series tires, but there was some rubbing against the wheel well inserts, so they dialed back to 245. This would explain the lower than expected gc.
They put those tires on just to make it look more trucky for its intro. They never planned on having anything other than the stock tire size on it for general consumption. . .Kind of a lame false advertising move if you ask me.
That's a pretty large tire for a mid-sized truck. Is there any midsize that comes stock with tires larger than 32"?
Edit: The Gladiator comes with 33s.
Do 255/70/18's rub?
Yes, largest tire w/o modifications is 30.5.
Tire size will be more limited by width than by diameter. Additionally, a lift will make clearance problems worse.
Some 265s fit and some rub, depends on the mfr's tire profile.
The 245s allow chains (cables) to be installed.
Yep. G2 RL transmission (6AT), rear diff, speedometer and front fenders all came from the G3 Pilot and were designed for 245/60R18 tires. Changing tire size would have required modifying or recalibrating all those things. Some of us got a little excited to see the G2 RL debut with 265/60R18 Destination AT tires, but that faded fast when we learned those tires rubbed and were only swapped in for the show.
Yeah, I've never understood why Honda decided to give the RL only 7.87" of ground clearance. They justify it on fuel economy grounds, but all Subaru vehicles have 8.7" of ground clearance, including the Impreza. It's a shaky argument to say the least.
I just installed the traaxda 2" front 1" rear lift on my 2019 ridgeline and got 26.7 mpg 35 miles of driving this morning to work. and average 22 +/1 0.5mpg between 50/50 city highway driving (live in chicago) so honda is very misguided on the lift mpg issue.
I also have 265/60r18 AT tires on it. STill drives amazing as well
One of Honda's major goals for the G2 RL was to claim it had the highest mpgs of any gas-powered midsized pickup. They made compromises to meet that target...and still only beat the competition by 1 mpg in city/hwy combined rating. Everything was considered in light of fuel efficiency. More drag from taller height and increased underbody turbulence does affect mpgs, at least to some extent. Tucking the wheels into the wells with limited clearance is another nod to fuel efficiency. Their market studies indicated that most US pickup owners rarely if ever take their trucks off-road, so "about 8 inches of ground clearance" was considered "ample" (yes, they even used that word in advertisements).
I agree that plenty of US truck buyers would consider the RL too low for off-road travel, especially with its vulnerable under-belly. But the lower center of gravity contributes to the RL's amazing handling characteristis and reduced rollover risk. I understand Honda's logic but decided I needed more clearance and would accept the trade-offs. I went with the JS 1.5/0.75" lift and 255/65R17 AT tires and have no regrets. WIth light-footed driving, I am getting 25 mpg hwy/20 mpg combined and enjoying the improved "soft-road" capabilities.
Subaru probably isn't the best comparison. They aren't great on fuel, especially given the size of their motors.
Sent from my SM-G973U using Tapatalk
Seriously, if you are worried about ground clearance when buying a truck/SUV, you shouldn't also be worrying a whole lot about a few less mpg. Our g0vernment has apparently succeeded in brain washing almost the entire population in a vibrant shade of "green".
41 - 52 of 52 Posts
