41 - 45 of 45 Posts
I happened to work for Bridgestone's materials engineering section years after that happened. Admittedly, ALL tires that come OEM on a vehicle are cheap. The reason for this is two fold-- Vehicle manufacturers are only looking for something that will last 15,000-20,000 miles tops, and spend as little money as possible.
I've never had an OE tire on any of the 33 automobiles I've owned last such a short distance. The OE Michelin tires on my 2010 Ridgeline were on track to last 75K miles when I sold it with 54K miles on it. @silkiechicken had 4/32" tread remaining at 88K miles on their 2017 Ridgeline's OE Firestone tires. I got 50K out of the OE Goodyear tires on a 1999 Regal. Even the high-performance rubber bands tires that came on my Tesla are on track to last 40K.
I'm not convinced that the lowest bidder always wins. If they did, we'd see new cars coming with brands that many people have never heard of like Salun, Milestar, and Sentury - not recognizable name brands like Goodyear, Firestone, and Michelin.
You are in a northern climate (Montana) so the a/c probably manages fine there. As for your satisfaction with the heat, it could be a combination of factors. Maybe in northern climates you are more bundled up when driving in winter, maybe you are naturally more acclimated to cold temps, maybe ??? But you must have a very rare Honda that doesn’t blow cold air on your feet when heat is split between two zones.
Also, your experience is with a single model (Ridgeline) from a single model year. Some of us have owned quite a few Hondas across decades. In my case a ‘95 Accord, ‘06 CRV, ‘07 Pilot, ‘14 Ridgeline. All have had a/c that struggles to keep up in hot temps, and all blow cold air on your feet if you split heat with another zone.
Please pardon me, 100 degrees is 100 degrees wherever one lives. Our Ridgeline’s A/C did us just as well living in SW Oregon with its significantly higher humidity levels. Our last trip at 40 below we were comfortable with no outer garments. The mode was set to split between windshield and floor. The temperature set at 65 degrees with the fan blowing at 2 or 3 bars. It was not even working hard. To add to our personal experience, I try to make it a point to seek out other Ridgeline owners when I get the opportunity and I hear mostly total satisfaction with their Ridgeline’s. If I wasn’t a part of this forum, I am thinking that I would be totally ignorant of how problematic the Ridgeline is supposed to be.
Bill
Ford/Firestone proved to the world that manufacturers sometimes conspire with recognizable name brands to put less costly inappropriate tires on vehicles. Sure some folks can under-use them and get adequate service life if they pay close attention to tire pressures, and sure sometimes manufacturers may actually put good tires OEM at the high end. But the point is caveat emptor. In the past I have purchased pricey Volvos that I refused to accept until the dealer upgraded the tires, because I intended maximum hard usage.
I would really like to hear from Honda about this. The $25 in refrigerant I used to get my system working to an acceptable level is not something that will break my finances, but it's just one more little pain in the backside for a vehicle that was over $47K out the door and I'm making payments on for another 2 years.
First off, let me just say that I don't doubt your qualification for making this statement based on your experience with the Ridgeline. You can work on my future Ridgeline's AC anytime....
I just have one question... If I take my Ridgeline under warranty into the service for the AC, the dealer will get paid for performing this service by Honda; presumably for the parts/refrigerant and labor. Admittedly, I don't know what's allowed charge for this service, but venture to say that is more, a lot more, than just cost of the refrigerant.
Not filling up the AC system with the correct weight of the refrigerant is probably counter productive on the long run. Maybe some "creative bookkeeping" can make this an attractive option, but it's doubtful.
Believe me when I say that filling up the AC system with a top off of freon isn't an exact science. If it needs a little shot of freon I've done it a bunch of times in many different cars. I only screwed up once and overfilled and that had to be pumped out by a shop. Otherwise a little bit of XYZ1234 isn't going to hurt the system if it's already short of it.
41 - 45 of 45 Posts
