Most of this information I've already posted, but it's scattered across multiple threads. So please excuse the long post, but I'm just putting my towing experiences together more concisely which will hopefully be easier for anyone else to find in the future.
I'm towing a 2022 Lance 1475. This one:
I installed an Andersen weight distribution hitch, detailed here.
I also detail in that post how I ran my rig across a CAT scale to get my weights. Loaded with the basic camping essentials, my travel trailer weighs 3860 pounds.
After this weigh-in, I added my full-size spare tire using a home-brew spare tire hitch mount. More info on that hitch mount here.
The fabricated mount weighs 30.0 pounds and the mounted spare tire weighs 64.0 pounds for a combined additional 94 pounds added to the rear of the camper. Because of this added rear weight, I was able to pack more into the front storage area without overloading my tongue weight. This includes my Champion dual fuel inverter generator, extra propane tank, and more. I'm sure that adding all this weight brings my total load up into the 4100 - 4200 pound range.
So I have a ZF 9-speed equipped Ridgeline towing a 7' wide travel trailer that weighs about 4200 pounds. Off the top of my head, I'm not exactly sure how tall the trailer box is, but I know that at the topmost protrusions, it's 10' 3" tall. This represents a significant aerodynamic drag as highway speeds increase.
While towing, I by far mostly set the cruise at 65 MPH and set the transmission in Sequential mode, locked into 5th gear using the paddle shifters. If I see a long flat or downhill section, I may shift to 6th. Low hills are no problem for 5th gear. Moderate hills may cause my speed to fall off a little, which I'm fine allowing to avoid shifting and generating more transmission wear and heat. But if the hill is somewhat steep and/or long, then I'll have to downshift into 4th which the Ridgeline has no problem generating enough power in to maintain speed. At 65 MPH in 5th gear the engine runs at almost exactly 3200 RPM.
Mostly out of curiosity, I developed a spreadsheet to figure out engine RPM vs road speed. This RPM-to-Speed and Speed-to-RPM calculator worksheet isn't super-pretty, but it works; and each calculation step is visible so it should be easy for anyone to re-create. Changing the items in yellow including tire size updates the results in green.
I also purchased a ScanGauge III specifically so that I could monitor my transmission temperature. At $270 as of this writing, a ScanGauge III isn't exactly cheap but it works very well. It auto-detects your vehicle and then presents you with a list of known data that it can read. You simply choose from the list what you want to monitor.
The ScanGauge II is the previous generation unit, but can also display otherwise hidden information. At $140 as of this writing, it's certainly a big step less expensive. It requires you to manually enter the correct codes to display Honda-specific data. There is a list of these "X-Gauge" codes here.
Another much less expensive way to monitor the transmission temperature is with a bluetooth OBDII code reader and a phone app. For example, I had good luck with a $30 Veepeak reader coupled with the Car Scanner phone app. You'll likely need to know the custom PID to enter into the Car Scanner app in order to read the Honda-specific transmission temperature. A list of custom PIDs is here.
With any of these OBD port tools you can monitor the transmission temperature, as well as many other obfuscated data points such as VCM status, transmission gear, etc.
Here's an example of my ScanGauge III display:
What I've discovered is that when locked into 5th gear for long distances, the transmission temperature could virtually be used as an outside air thermometer by subtracting 98°F from the trans temp. So if it's 90° outside, the transmission temperature will read 188°. If it's 55° outside, the transmission will read 153°. Downshifting to 4th for a steep hill causes the temp to climb, but shifting back into 5th once again settles the temp back as expected. Upshifting to 6th was... interesting. It seems like 6th may generate more heat than 5th within the transmission, but the lower RPMs offset that. So 6th will run slightly cooler than 5th, but it takes longer for the temp to settle. 5th happens to be 1:1 with 6th and above all being overdrive gears, so maybe there's some truth to that.
These are all very reasonable transmission temperatures. From what I've found on the interwebs (mostly from transmission cooler manufacturers so take this with a grain of salt), at as low as 240°F, varnishes can begin forming in the transmission fluid. So keeping the temps under 240°F is a good idea. An old rule of thumb used to be to expect transmission temps to be approximately 100°F over the outside air temperature. When not towing, my RPMs are significantly lower and my transmission temp is somewhere around 70°F-ish above outside air temps.
Unfortunately, fuel economy while towing this camper (like any solid walled camper) is pretty poor.
I've been keeping good track of my fuel economy all summer. NOT towing, I've averaged 27.1 MPG via hand calculations (not the dash indicated values) over the course of over 4,000 miles in the last few months. For reference, over the same fill-ups, the dash indicated an average of 28.0 MPG. So my hand calculation is 0.9 MPG lower than the dash display (3.2% lower). I'll admit that I've been specifically trying to get good fuel economy while conducting a range test, so this average might be slightly better than I'd get just driving normally.
On my recent camping trip, I averaged 10.7 MPG over the course of about 1500 miles when towing for the entire tank. For reference, over the same fill-ups, the dash indicated an average of 11.1 MPG. My hand calculation was 0.4 MPG lower than the dash display (3.6% lower - so about the same percentage). Obviously driving at 65 MPH into a headwind produced the worst fuel economy (my worst was 9.3 MPG). But driving on country roads at generally 60 MPH with slowdowns for occasional small towns would increase my fuel economy up to around 13 MPG.
My ScanGauge has an editable field it uses to accurize the fuel economy displays. Through trial and error, I have it set to -3%, which checks out according to this data.
I've now towed that camper for almost 5,000 miles this summer and am happy to report that the Ridgeline does a very good job towing, as long as the expectations are reasonable. I've experienced no problems with the transmission running too hot. Actually, the hottest I saw the transmission get on my whole camping trip was while I was NOT towing. I was driving slowly up steep switchbacks in the Black Hills and saw the transmission temperature peak briefly at almost 210°F when the outside air temperature was in the low 90s. Clearly speed helps to get more air through the factory transmission cooler and driving slowly at higher RPMs generates more heat.
