When stopped and START/STOP switch pushed to shut off the engine, the engine shuts off but the car remains in accessory mode. If the switch is pushed again, a message tells you to double tap the switch to exit accessory mode. If you do that, the accessory mode cycles and it starts all over again in an unending loop.
Restarting the engine and shutting it off again does not solve the problem. Any ideas?
