I just had my first oil change on my ‘24 Ridgeline after 5300 miles and six months of driving. The Maintenance Minder said oil was at 40% but registered “A16” which indicates engine oil and differential fluid needed to be changed. This is my 4th Ridgeline all driven the same and I have never seen a an oil change icon when the oil was at 40% nor a differential change at this mileage. I always changed the diff. at 15k. Any thoughts? I had the oil changed at the dealership and we agreed on changing the differential at 7,500 miles.
NAPA sells a differential fluid called Eneos Import DPS Fluid the label says it’s compatible with Honda/Acura DPSF II. It’s half the price of Honda branded DPSF, any problem with using this product? I see no reason to pay the dealer for a two quart drain and refill.
