I have a 2017 RTL-E with 45000 miles. I did an inlet valve cleaning using Berryman cleaning solution IAW their instructions except I raised rpm to 2K during the application of the cleaning solution. After waiting the required 30 minutes of soak I went for the 10-minute drive at which time the check engine light came on and almost every failure alarm possible started coming in (e.g. steering failure, AWD failure, hill maintain failure) and I was unable to raise speed above 40 mph without engine bucking. Upon returning home, I used my OBD reader to clear all codes and then the truck ran fine. All I can figure was that one of the O2 sensors sensed a bad reading and that sent the ECU into fault. Is this an expected occurrence; anyone else seen this?
