1 - 6 of 31 Posts
Mike B
Discussion starter · #1 ·
What a long wait. I first checked on a canopy in March of '05. Then the promises of "in six months", or "in the beginning of Feb." Yada, yada, yada....
Anyway, it's on and I really like it. So do the "Boys". Nothing like dog nose snail tracks all over the inside glass of a spendy new toy right? Sorry. My dogs are animals.
I got the "Leer" and added the "Sports Package" which includes a "Thule" Rack and your choice of an accessory. I chose the "Load Stops" and tie downs. I build Custom Homes in Southern Oregon. My intent is to throw a ladder on top from time to time during my trips to job sites where I don't need to drag my whole full-sized truck/trailer set up out. The package also includes a cargo net attached to the ceiling for stowing this and that.
The quality of the unit is great as far as I can tell. I'm a pretty picky person. My background as a finish carpenter can be a curse at times.
"Leer" forgot to install the "Keyless Entry" I opted for. The Dealer has ordered it and will install it next week. It does work off the Honda key, so one less key on my ever-growing ring.
The canopy changes the looks of the truck dramatically. Personally, I like it, as does my Wife. Some will play the "SUV" card and dis it this way and that way. But, in the end, it's a fairly arrogant stance to tell others that what you think a truck is for, is right for all.
I have an open truck. It's 3/4 ton, it's diesel, it pulls like a sum b---h, and it's got a 12'x7'x7' utility trailer behind it most days. It also sucks fuel like flushing a toilet. In fact, the speedo has a race with the fuel gauge and wins most of the time! LOL Not really, but you get the idea.
I needed something inbetween. Something with some creature comforts. Something to take an Elderly couple out to look at prospective home sites. Something to keep a load of light fixtures dry in the dead of winter. Something to put the "Boys" in so they can join us more often. And something that cleans up nice for dinner downtown. My Ridgeline with a canopy does all that and more I'm sure.
So, for me, one more goody off the list. Wheels and tires are most likely next. Maybe the lift kit. I love the urban look with 20" or 22" wheels and low profile tires. But, for me? I need to get to work in the winter. Through snow on the mountain pass between Oregon and California, through mud on job sites and rainly, icy slippery days. I'm probably going after an "off-road" look of sorts. I'll post pics as things happen.
I was already down to the local sporting goods store looking at all the goodies for the "Thule" system...Hmmmm....one of those tube frame "baskets" might do well with an off road look.......What to do? What to do?
Have fun with your own new toys!:D
Discussion starter · #5 · (Edited)
Howdy,
Sure I'll get some more pics soon.
I do know that the unit is anchored with four long 1/4" "J" bolts that hook on the rear pair and the upper front pair of factory hold-down hooks. I still have use of the hooks. The slick part is that the angle of attack for the front pair is such that it pulls down and foreward to seal the canopy at the cab. The rears just pull down.
One thing I'm not thrilled with, which is no fault of Leer, is the installer left the fuses and wiring for the 3 outlet 12 volt plugs hanging loose. I have some flexable, split, wire cover/harness material that will solve it. It was just a bit cheesy on their part. In fact, I think I'll make them do it when I go back for the keyless entry.
I'll try to be there to pay attention to where they wire it. The installer did mention the fact that it's a real pain to do, based on the amount of time it takes to trace the leads to the actual mechanics that cause the driver's door lock button to go up and down inside of the door itself..
The Sport Package really is worth the extra $400. The "Thule" rack and track mounting system is worth that (or better) without the Load Stops, quick cinch ropes and tie down straps. Plus you get the 3 outlet gizmo, an extra battery operated interior light (I believe it's extra) and the cargo net ceiling.
The wire cable you noticed is the escape release like car trunks have these days. A result of a successful law suit, somewhere, some how, no doubt...
Discussion starter · #17 ·
Well I finally got around to taking some more shots of things some of you were asking about. The mounting system and other features of the Leer canopy. so, here they are! Forgive the dust and the nose prints. I am a contractor and my dogs are ANIMALS! LOL
The mounts are 1/4" J-bolts. The front set pull foreward and down. The rear set pull straight down. They hook onto the in-bed tie-down points. I can still use all of the hooks.
The "Sports Package" comes with the Thule rack, one accessory (I chose the load stops for carrying a ladder), extra aux lighter plugs and a ceiling mounted cargo net.
I added the keyless entry as an option as well. I works off the Honda key.
Hope this helps!
Mike
Discussion starter · #19 · (Edited)
Thx all and Jerseyguy.
Nope. No leaks after the first day. I had one trickle the next morning, while washing the truck, about 1 1/2 feet in from the driver's side on the roof. I'm told it takes at least 24 hours for the canopy to "settle in" and make a final seal. I believe this as during the install I noticed the canopy was about 5/16" from touching the cab roof in the center third of the canopy. I pointed this out to the installer who said there was a double seal in that area.
He's right, there is, but I still made a mental note to pay attention to the area. I called the place I bought it and advised them to add some more time to look at the leak when I came back for the install of the Keyless Entry. About a week and a half later, I went in for the work. I stood on my running board and looked at the spot on the roof where the canopy had been 5/16" high. It was flat, tight and conformed to the cab.
There was "maybe" an 1/8" gap that was consistant along the entire run of the canopy/truck connection. Good to go. He retightened the four bolts and it didn't budge. I have washed the truck a number of times since, spraying with purpose at the seal without any leaks.
I even left the side windows open by accident yesterday and, Murphy's Law, we got some light showers. It didn't even leak into the interior with the windows open while parked all day in the rain!
I'm adding a couple pics showing the window operator and one of the window fully open. It only opens as a vent-maybe 1 1/4" max. Seems to be enough for driving, but if you wanted to camp inside it would get a might stuffy I bet.
I thought the mounting was great, as there are no holes in the truck, the hold down hooks are still usable. Most times, in my experiance, simple is better. Those bolts are plenty stout.
Someone asked about cost as well. Sorry, I have not been logging on as often as I'd like....OK, the canopy was $1650, the Sports Package was $400, and the Keyless entry was $150. There's no sales tax in Oregon (Yippee!), so my total cost, installed was $2200.00. Looks like wheels and tires will wait a bit. HAHA :eek:
Considering the last time I looked at canopies they were less than a grand, I was bit shocked at first. I called around and the price seems pretty close to everyone else's. Plus, I have someone locally that I can go complain to should any issues arise. This area (Southern Oregon/Medford) is nicknamed, "Mail Order Medford" because it seems like EVERYTHING has to be special ordered. So, having a local dealer, at times, is worth a buck or two more than one might spend in Portland or other larger cities.
I can't really help with the blind spot questions. I have driven with side mirrors so long, in so many other trucks (With highside toolboxes or canopies, and pulling trailers daily, or in a van) I rarely look at the center mirror. Plus, with Dumb and Dumber in the back, they just about block out the sun. My rear view is usually of two big ol' noses sticking into the cab! :D
The Leer logo on the rear window is a 3D sticker. I am planning on removing it as well. The windows are tempered glass not Plexiglass. I asked for this very reason.
I have a nice "Harley" sticker that will replace it. I'll end up with Honda's first "Harley Edition" pick-up! HAH. Ford, step aside! Honda's got a truck now!
PS- The "Boys" like all the fan mail!
Discussion starter · #23 ·
Howdy,
Sorry about the slow responce. Lots going on these days.
The side windows open slightly as a vent at the lower, rear corner, by about an inch or better. When they are open, and you crack the rear window of the truck, the air moves through at quite a clip.
These days, as a Builder, are more than bleak. I am going to have to give up my Ridgeline. It doesn't have the towing capacity I need to pull my work trailer. The jobs I am getting are usually as a Carpenter, so the Ridgeline has to go.
That said, I am looking to sell the canopy, cargo net and the billet grill. The whole truck for that matter, if anyone knows of anyone looking.
I spent $2200 on the canopy, but would take $1600 OBO cash. I has the Sportsmans Package on it. That includes the Thule Roof Rack system, the cargo option with tiedowns, additional interior lighting, a three plug 12v pod and a ceiling mounted cargo net.
I want $100 for the grill and $40 for the net.
I need to get pay off for the truck itself. Something like $23k, give or take. The truck has 34k miles on it and still runs like new.
Let me know if anyone is interested.
Mike
1 - 6 of 31 Posts
