Mixing oils?
1 reading
2K views 6 replies 6 participants last post by  Nuke83
I have almost 4 1/2 quarts of various 5W-20 full synthetic oils, I have Valvoline, Castrol, Penzoil, and Mobile One. Everytime I buy the 5 qt bottle and have that "extra" 1/2 qt, I save it.
My question is this........................
Is OK to mix all those different brands together and use them to change oil next time? Or should I buy another 5 qt bottle of one brand? I assume mixing wouldn't be a problem cause if you stop to add a qt someplace they don't always have the same brand as long as it's the correct weight and type (syntetic, semi synthetic, or plain Dino oil................), should be fine right?
Only thang that makes me think not is I know Penzoil is synonymous with detergent oils so I am leary about Penzoil. In the 70's Penzoil was considered the worst thing you could do to an engine, now, it sounds like they have pretty good syntetic oil from what I read on the interwebben, and everything on there is the truth right?:act035:
#7 ·
So long as they're all the same viscosity (which you state they're all 5w-20), then it's perfectly fine. You'll do no harm. No different than if you found yourself a quart low between changes and happened to add a different brand.
