It may not hurt, but let me ask, do you really like the car? then by all means get it changed, here's a perspective from an old wrench, who is sickened by todays miracles, that have entirely changed the automotive common sense..... not.........the recommended svc is 5000 miles but I as well as many of us old timers recommend 3500 on a new engine, even engine builders will tell ya 3500. reason being? assembly Lube oil, filter picking up debris in engine after running 3500 from new, basically a common sense issue. But here come the nay sayers, 'Ohhh the assembly lube they use today doesn't clog or gel up" Ohhh they manuf tens of thousands of engines this has never been an issue" OMG!!! synthetic oils last twice as long, that oil changing at 3500 for a new build is a joke anymore. Ok then lets look at it this way, yes engines fail from bad assembly, oh it's not a huge number unless you are say Kia, Ford or GMC, oh wait!!!Stilantis. ooops did I post that? So here we are, say just 10% of those million engines fail due to a plugged oil filter or gummed up excessively hot oils which will show during an oil change, say it's YOUR vehicle that does, you know like that 1 in a million chance in life, lightning strikes you. Sometimes the older ways are best. New engine, break in, new oil and filter between 3500 and 5000 miles. Do what you want to. I just had a knock down drag out with Honda dealer on kids CRV 2025, they refused to change her oil until 5000 miles, her being in college, the car was 9 months old before she got to 5k for honda to change the oil. (she's in another city in state) so even the dealers, the bonafide dealers exceeded even Hondas recommendation for 5,000 miles or every 6 months, hmmm oh and they tried to sell her a washer fluid reservoir 400,fuel injection clean 298, and lets not forget ashtray clean 500/Oh wait!!! CRV doesn't have an ashtray!!!! Honda needs a service bulletin asap!!!! Then last week on our PP which just hit 40k miles they said needed fuel injector clean, 298.00 I passed. Called Honda Ney York, they explained they don't recommend it at 40k hmmmmm things we learn huh?? On a side note OP stated" Is diff ok?" lesson learned, had other hondas 4x4, and odyssey, prelude, I let a 2nd mkt dealer change diff fluid once, they used I believe STP or some mker brand, found out the hard way only honda diff fluid will work and stops chatter, lesson learned on that one. good luck with you car,
